Sorry for being late , I will try to reply all of you .
Thanks for every one .
it would help if we know what you are trying to build ?
fluxpen : unless you go about messing with SMD parts : not needed. solder has flux in it
Arduino : eh .. how many is up to you ...
Helping hands ... useless. i never use those things. they fall over and are generally annoying. use thumb and index finger to hold solder , middle finger and ring finger hold wire to be tinned. other hand holds soldering iron ... done.
heat sink for soldering ? you plan on putting that in the baking sun down there in saudi arabia , let it heat up and then use it to solder ? i think you mean soldering iron right ?
flash circuit ? what do you want to do with that ? (i'm a bit spooked on this one since you say "this is all on my 'mined' for now "... )
I do not know what I am going to build yet . I am studying Electrical Engineering so I will try to experiment everything I learn in university , and will do other things like fixing electronics modifying them for my needs .
I think I will do SMD so I will get the flux
I think I will not get the helping hands unless I need them in future . I will try your method .
For the heat sink (I liked your idea , may be I try it) , I meant the clips that get the heat so it will not affect the parts .
You may understand this better than my explanation
http://www.kpsec.freeuk.com/solder.htmFor the flash , I want to use it as Joule Thief .
BoredAtWorkI will try to build one and see if it works or not .
MechatrommerI know it was a joke (it is good to be fun even in work)
I will get the solder braid . Thanks for adding it .
LEECH666Good advice , will try to build it myself and I will get tow Arduino .
I think I will leave one fixed for lights in my house and one for work with it in my Lab .
Maybe we have to choose that for him also.
Only I forgot to tell in first post .
I think by "heatsink" the OP means those little gadgets that look a bit like flat alligator clips,that are supposed to be used to protect small leaded components,wire insulation which shrinks back when soldering,& things like that.
Yes , this is what I meant .
I will add what I have in my lab so you all can tell me what I really need to get .Now trying to get Fluke 87 v or better on eBay (I only have Sinometer MS8268) .I read that the fluke life warranty does not include what is sold on eBay .
Do u think I will need the warranty so I will pay the extra money for an official seller ?
Can I live without the warranty ?
How much should I pay as max price for good used one or new one in eBay ?THanks for all of you
