With summer fast approaching I'm going to be having some free time on my hands and I would like to build my own PSU for my homelab which I only started recently. I have searched the forum regarding similar threads however I didn't quite find what I was looking for. The thing is that even though I have a good idea of the features that I'd like in my PSU, and the basic circuit topologies of a regulated PSU, I don't think I'm knowledgeable enough to design the whole circuitry from scratch by myself.
The features I would like are:
- Dual rail supply, with variable voltage ranging from -15V to +15V (or just from 0 to +15V and then connect accordingly when -ve voltage is required)
- Current limiting capabilities
- And perhaps an LCD that displays voltage/current just to make it interesting?
Any other features that I might have missed which you guys think are necessaryFrom my knowledge I am assuming that first of all, I will have a full-wave rectifier that would convert the mains AC voltage to an unregulated DC voltage. This stage would then be followed by a buck converter to step-down this unregulated DC voltage. However I'm not sure how to proceed from there to make the regulated dc voltage variable, to implement current limit capabilities and to display the voltage on an LCD (probably done by some PIC?) I won't be experimenting with the mains whatsoever until I simulate the whole circuitry and know for sure what I'm doing.
With this said, I would like to know how I should approach this in the first place. I don't know what I require exactly. I am in no hurry at all and I'm doing this to learn however I require some directions.
Any suggested readings regarding the above mentioned stuff? Or perhaps are there any schematics which one can find online and could build on? I'm open to suggestions
