Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Quick question about shorting jumper pins
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Quick question about shorting jumper pins (Read 1427 times)
Mp3
Frequent Contributor
Country:
on:
January 27, 2019, 12:16:05 pm »
Hey everyone.
I have a 2x6 row of pins and two consecutive pairs need to be jumped like so
II----
II----
I dont have enough jumpers around to accomplish this and it is only needed for one task and then the jumper will be removed.
Since the two jumper pairs are touching each other. Would it be safe to roll up a tiny ball of aluminum foil and put it between those pins to short all 4 out?
or is it risky to not only jump them as pairs? (this is an IDE hard drive)
Logged
High school graduate
mariush
Super Contributor
Country:
Re: Quick question about shorting jumper pins
Reply #1 on:
January 27, 2019, 12:24:17 pm »
No, without knowing exactly where those pins go, you can't.
Logged
soldar
Super Contributor
Country:
Reply #2 on:
January 27, 2019, 12:24:53 pm »
You don't have two jumpers? Do you have one? None?
At any rate, you could make the jumper with a bit of cardboard with aluminum foil glued to the side.
I would not recommend shorting all four pins. Just in case.
Logged
Doctorandus_P
Super Contributor
Country:
Reply #3 on:
January 27, 2019, 12:29:07 pm »
You can use a piece of bare copper wire and wrap it a few times around the pins you want to connect while the power is off.
This is a lot easier if you have some spare 0.1" header pins in 2's as a mold.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
