I should say up front that I'm not a programmer.
I just bought a new inverter (Goodwe SBP G2) and I need to control it with modbus, I've got the inverter installed and I have a working connection using a waveshare modbus TCP to RTU converter.
So I bought this inverter because the modbus was already reversed. The vendor has changed it and won't provide a document.
So I'm using node-red, the previous modbus implementation would provide the serial number when you read 0x0200 I figured out that that has changed to 0x07D0.
So does anyone have a way to quickly enumerate all the addresses, so I can use the SolarGo app to change something and search modbus for changed values?
Thanks.
Richard
