Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Random values in MegOhmmeter
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Random values in MegOhmmeter (Read 939 times)
Jasonbit
Regular Contributor
Country:
on:
January 30, 2019, 12:25:47 am »
Hello,
I am trying measuring the insulation resistance of this transformer trough this MegOhmmeter (
https://uk.farnell.com/tenma/72-9400/tester-insulation-250v-500v-1kv/dp/2064096
). But I receive the weird values. In this images you can see three diferrent value during resistance test. The values are always changing!
Image 1:
https://postimg.cc/Hjy1Zyzc
Image 2:
https://postimg.cc/4YwD7bfM
Image 3:
https://postimg.cc/kVpLwJtv
What could be happening?
I already checked with a multimeter and got the correct voltage values (250VDC, 500VDC and 1000VDC). And the test applied to a multimeter has a value of 9.9M Ohm
Thanks
Logged
RoGeorge
Super Contributor
Country:
Re: Random values in MegOhmmeter
Reply #1 on:
January 30, 2019, 12:34:44 am »
Try measuring without the 2 spool of wires, using shorter leads (probes) instead.
My best guess is those 2 spool of wires are nothing but huge coils, acting here as antennas, thus altering the measured value.
Logged
https://hackaday.io/RoGeorge
https://rogeorge.wordpress.com
Andy Watson
Super Contributor
Reply #2 on:
January 30, 2019, 12:51:14 am »
Can you power the meter from a battery? If not, can you ground one of the power supply leads? I suspect that your power supply is coupling a large mains component into your meg-ohm meter - which is probably saturating the front-end of the meter. And as RoGeorge points out, this will not be helped by those long antennas.
Logged
graeme.c.payne
Newbie
Reply #3 on:
January 30, 2019, 01:18:47 am »
I agree with the above. As a general rule, the connection between the unit under test and the test/measurement equipment should always be as short as practical.
Sent using Tapatalk
Logged
Jasonbit
Regular Contributor
Country:
Reply #4 on:
January 30, 2019, 01:49:58 am »
Thanks to your help.
Yes, you are right. I did this test:
image1:
https://postimg.cc/7bs2xbTN
image2:
https://postimg.cc/LnJZhRtF
When I tested the transformed in the moment I press the button "Test" the value 685MOhms appear but disappear in the next second. Then it remains with the value1 MOhm. I repeat the process and I get another value.
Thanks
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
