If you combine sources in series, you will add voltages. If you combine sources in parallel, assuming they have the same voltage, you will add current. That works with batteries for example. But combining random source together, including batteries, can cause problems in practice. Power supply generally don't work well in parallel, unless they have been designed for that, because their regulation feedback loops may interfere with each other.
It would help to have a bit more context to answer your question.
