This is more for manufacturing, if you are hand soldering the part then I can't say I have had any issues.
Having said that I have parts that have been opened for months, in the anti moisture bags, the litmus card has gone all sorts of shades, but they still reflow perfectly well, luck of the draw I guess.
Depends on the environment, they have to warn you for worst case I guess, if it is kept in a relatively moisture free environment then you might not have an issue.
When you send the devices to a CEM or if they buy them in and stock them, they would probably have humidity and temperature controlled storage for parts of such sensitivity.
