Author Topic: RC time constant  (Read 5809 times)
Offline electrowhizTopic starter
  • Country: in
RC time constant
« on: August 21, 2019, 05:24:08 pm »
How to calculate the RC time constant of the attached circuit?
Offline Dave
  • Country: si
  • I like to measure things.
Re: RC time constant
« Reply #1 on: August 21, 2019, 05:53:21 pm »
http://sim.okawa-denshi.jp/en/CRCRkeisan.htm
You don't have a time constant as such in a 2nd order system, as you would in a 1st order system. What exactly are you trying to accomplish?
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline bson
« Reply #2 on: August 21, 2019, 06:04:47 pm »
Vc = Vs(1-e^(-t/(RC)))
The RC time constant is the t where Vc/Vs = 1-1/e
For the cascaded case, remember that transfer functions of serial elements multiply.
« Last Edit: August 21, 2019, 06:14:45 pm by bson »
Offline Dave
  • Country: si
« Reply #3 on: August 21, 2019, 08:12:46 pm »
Not quite. The second RC element affects the first one, altering the response. Your statement would be true if there was a buffer amplifier between C1 and R2.
Offline TimFox
« Reply #4 on: August 21, 2019, 08:48:49 pm »
When the circuit is more complicated than a single-pole R-C, the correct questions are what is the rise-time or bandwidth.
  • Country: in
« Reply #5 on: August 22, 2019, 03:14:47 am »
Hi, I just want to know the response of this circuit for step input. How long will it take for cap C1 and C2 to charge? Do u know any ways to find the duration it takes to charge?
Offline Ian.M
« Reply #6 on: August 22, 2019, 03:56:06 am »
If you know the component values and don't need an analytic solution, sim it with a SPICE program.
Offline Dave
  • Country: si
« Reply #7 on: August 22, 2019, 10:34:32 am »
If you do need an analytic solution, the URL I provided above has everything you need.
Offline rstofer
« Reply #8 on: August 22, 2019, 02:48:12 pm »
That's a great link!  You just know the thing is a second order differential equation and that Laplace Transforms are going to show up somewhere.  MATLAB can probably plot the equation for particular values.
LTspice is one way, Runge-Kutta and Fortran is another.
For a second order system, what does "time constant" even mean?  63% charge on the first capacitor or on the second capacitor?
Offline bson
« Reply #9 on: August 22, 2019, 04:55:15 pm »
Or just calculate both time constants and let the teacher decide, if it's unclear.
Offline GerryR
« Reply #10 on: August 23, 2019, 12:25:36 am »
The first R-C group has a break frequency at 1/ 2pi R1C1 at 20 db / decade (1st order filter); the second R-C group has a break frequency at 1/2pi R2C2 at 20 db / decade (1st order filter).  Where the frequencies overlap, they roll off at 40 db / decade, a 2nd order filter.  :-//
Still learning; good judgment comes from experience, which comes from bad judgment!!
Offline Dave
  • Country: si
« Reply #11 on: August 23, 2019, 01:03:10 pm »
Well, let's put this claim to the test.
Seems to hold up, -20 dB per decade after the first break frequency, -40 dB per decade after the second break frequency. So far so good.
Now let's switch their values.
Hmm... Weird, it suddenly behaves just like a 1st order LPF. The corner frequency seems to be closest to 1 / (2 * pi * R1 * C2).
It's almost as if the second pair of components is affecting the response of the first pair. ::)
Offline Mattjd
« Reply #12 on: August 23, 2019, 01:55:30 pm »
there's a lot of heuristics, but for example, if you have a nth order system, depending on location of poles/zeros and what their residuals are (wrt to the dominate poles), you can ignore them and treat it as a 2nd order system. Same applies for a second order system
Offline The Electrician
« Reply #13 on: August 23, 2019, 04:11:39 pm »
(Attachment Link)
(Attachment Link)
You didn't plot the switched value version over a wide enough frequency range:
The following users thanked this post: Nitrousoxide
Offline bson
« Reply #14 on: August 23, 2019, 04:40:05 pm »
Please don't do posters' homework for them here.  Hints are fine, but they need to do their own homework!
Offline Nitrousoxide
« Reply #15 on: August 23, 2019, 05:00:23 pm »
A good exercise would be to derive the transfer functions for a fully passive second-order network and a cascade of 1'st order networks with an intermediate buffer.
You will (or should) see that the "center" frequency will remain the same (Hint: the 0th order term in the denominator when simplifying), Whilst the 1st order term will vary. The first-order term contains information about the system damping and thus can lead you to an answer about the system settling time.
As mentioned before the "time-constant" is not really applicable to second-order systems. However, if the system is critically damped (zeta = 1), both the poles of the system will be purely real and exist on the same point (repeated root), thus it can be seen as two identical networks charging (Note: This is only for the buffered case). Think for what values of R and C this would occur.
Offline Dave
  • Country: si
« Reply #16 on: August 23, 2019, 06:01:02 pm »
The point stands, you can't evaluate a second order system by simplifying it to a combined response of two first order systems, because without an intermediate buffer, they affect each other.
Offline GerryR
« Reply #17 on: August 23, 2019, 11:31:54 pm »
Your point is well taken, but why would anyone, or should I say for what reason would anyone, put the higher break frequency of a low-pass filter ahead of the the one with the lower break frequency in a stacked filter like that?  Maybe just to prove a point??
« Reply #18 on: August 24, 2019, 07:09:55 am »
Time domain and phase response. This is could be potentially critically important for system compensation. Say for maximising time-domain performance whilst ensuring stability. (i.e. say you want an underdamped response versus a critically damped response)
Offline rstofer
« Reply #19 on: August 24, 2019, 01:52:13 pm »
What math package did you use for that plot?  It looks like something I should be playing with.
Thanks!
« Reply #20 on: August 24, 2019, 02:07:15 pm »
Thanks!
It's Mathematica.  Along with the other top-of-the line packages, Maple and Matlab, its commercial version is expensive.  Student versions are available [for verifiable students  :)].  I'm still using an old version of Mathematica.
There's a free package, Maxima (http://maxima.sourceforge.net/), which is comparable in performance.
Offline janoc
« Reply #21 on: August 24, 2019, 02:32:05 pm »
Thanks!
Or save your money  and aggravation and use JupyterLab like everyone (well, almost) else for numerics:
https://jupyterlab.readthedocs.io/en/stable/
Jupyter has pretty much replaced Matlab for anything numerics and statistics (e.g. machine learning) related in research these days.
If you need symbolic math (that's where Mathematica and to a lesser degree Maxima & Maple excel), you can either use Maxima or SymPy from Jupyter ((https://www.sympy.org/en/index.html )
And, if you don't like the browser-based UI, Jupyter is just a frontend to Numpy and a lot of other Python packages which you can use from your favorite Python IDE as well.
« Reply #22 on: August 24, 2019, 02:37:40 pm »
I don't think this is homework.  If you'll look at electrowhiz's other posts, it appears that he is self-educating about RC circuits.
The following users thanked this post: RonFred2
Offline janoc
« Reply #23 on: August 24, 2019, 06:04:55 pm »
Also the school is out in most places for a few weeks still. So a bit early for homeworks  ;)
Offline Mattjd
« Reply #24 on: August 24, 2019, 07:04:57 pm »
Word of advice, stay away any symbolic math packages in python, they're garbage.
Numpy, scipy, sklearn, matplotlib, bokeh and pandas can do 90 percent of what Matlab does for free. No denying that.
What python lacks is a good symbolic engine and Simulink, both of which Matlab has. Simulink is still the preferred method of designing controllers in commercial industries.
« Last Edit: August 24, 2019, 07:07:56 pm by Mattjd »
