Author Topic: ATtiny  (Read 2203 times)
Offline Rihards VeipsTopic starter
  • Country: lv
ATtiny
« on: April 04, 2014, 05:17:42 pm »
I programmed my ATtiny microcontroller with an Arduino [Blink on pin 0] - the programming worked but I have a problem with my ATTiny - when I plug in the LED it turns on but doesn't turn 100% off, it stays at about 40%
Are there any solutions for that?
- Le Nub
Offline Neverther
Re: ATtiny
« Reply #1 on: April 04, 2014, 05:25:31 pm »
Schematics/code/chip?
Not all chips/pins supply the 20mA current arduino can.
Are you just connecting the directly to tiny pin and ground, or with resistor, or using internal pullup to light the led a little bit, or using it to control a NFET that drives some higher power led?
Offline 128er
Re: ATtiny
« Reply #2 on: April 04, 2014, 05:26:37 pm »
Did I understand it right? You connect your LED to PIN0? Do you mean PortB0? Did you program the TINY over the ISP-interface?
  • Country: lv
Re: ATtiny
« Reply #3 on: April 04, 2014, 06:01:27 pm »
Attiny85 1Mhz internal clock      -      not using a resistor
- Le Nub
  • Country: lv
Re: ATtiny
« Reply #4 on: April 04, 2014, 06:03:20 pm »
Led connected to PB0               programmed over Arduino as ISP
- Le Nub
