Author Topic: Replace micro-USB with USB-C on bluetooth earphones case  (Read 2714 times)
Offline jancelotTopic starter
« on: December 29, 2019, 02:31:41 am »
Hi, would like to buy some cheap bluetooth earphones from Aliexpress, however cheapest ones come with micro-USB. Since I want to have a single charger for all and no adapters, could I open the charging case, and replace the connector?
Something like that:
https://www.aliexpress.com/item/33011860929.html
https://www.aliexpress.com/item/4000339760924.html
Re: Replace micro-USB with USB-C on bluetooth earphones case
« Reply #1 on: December 29, 2019, 03:25:09 am »
Ok found a video here, pretty sick:
« Last Edit: December 29, 2019, 03:27:23 am by jancelot »
Online oPossum
« Reply #2 on: December 29, 2019, 03:39:41 am »
Eww. Not slick. Relies upon the shield for ground, and will not work with a proper Type C charger.
Offline coromonadalix
« Reply #3 on: December 31, 2019, 04:15:49 am »
And usb-c are reversible connectors per design .........
I would not do that kind of hack / mod,  it could toast the supply source  Ie: an charger, an computer   etc ...
Offline tooki
« Reply #4 on: December 31, 2019, 10:57:40 am »
In a nutshell, maybe.
This describes the requirements for USB-C power: https://electronics.stackexchange.com/a/327946
If (and only if) the device never needs more than 500mA of current at 5V, then you can get away with a relatively simple implementation. Anything more, and you need to get into more complex designs.
Offline zzattack
« Reply #5 on: December 31, 2019, 11:24:53 am »
Lovely way to scrape away the silk screen I must say  :wtf:
Offline tooki
« Reply #6 on: December 31, 2019, 11:50:07 am »
Indeed. I'll have to remember the drill-bit-at-an-angle method. So much more elegant and precise than the angle grinder I've been using!  ;D
Offline mikerj
« Reply #7 on: December 31, 2019, 12:24:56 pm »
Assuming the GB in his username refers to location, we have found the Butcher of Britain.
Offline tooki
« Reply #8 on: December 31, 2019, 12:49:18 pm »
It looks like it's a localized (translated) user name: in the embedded video above, it's showing up to me as "Mr.Satech FR", but when I open it in a separate window, "Mr.Satech US". (I didn't realize YouTube had this level of localization, but a quick search led me to a help page on how to do it.)
Looking at his channel, it appears to me he's a Turk living in France, which would explain the glorious grammar: "it is hack?" (Yes, is hack. ;) )
The following users thanked this post: mikerj
Offline zzattack
« Reply #9 on: December 31, 2019, 02:48:10 pm »
Well, it seems to work for the butcher here... Whenever I scrape silk to expose a copper plane, I start out with a hobby knife which already takes some careful handling. But it's fast, much faster than using the correct tool for the job (i.e. fiberglass pen), and the result is never nicely flat. Getting the exposed area tinned is hard because the solder flows very poorly. A few seconds touch up with fiberglass pen results in a much smoother surface and the solder attaches much better.
Offline mikerj
« Reply #10 on: January 04, 2020, 03:01:07 pm »
For scraping off solder resist I find a curved scalpel blade is hard to beat.
Offline sokoloff
« Reply #11 on: January 04, 2020, 03:21:02 pm »
If you are already buying something, why not just buy the thing you want in the first place and avoid all the aggravation?
Online wraper
  • Country: lv
« Reply #12 on: January 04, 2020, 03:37:04 pm »
What is that connector? It's not standard USB-C.
EDIT: Found it. Some China special without any data lines https://www.aliexpress.com/item/32885941456.html
« Last Edit: January 04, 2020, 03:44:50 pm by wraper »
Online oPossum
Offline aix
« Reply #14 on: January 05, 2020, 10:18:52 am »
LCSC sells this style of connectors:
https://lcsc.com/product-detail/Others_Korean-Hroparts-Elec-TYPE-C-31-M-17_C283540.html
It only has VBUS, GND and CC1/CC2.
« Reply #15 on: December 07, 2020, 01:50:05 pm »
A new video has come out, replacing USB-A and micro-USB with USB-C. Outstanding.
