I have a cheap UNIT-T UT30B and was looking at the tolerances at
http://www.uni-trend.com/en/product/2014_0801_919.htmlUnder the parameter tab I'm looking at the DC current row. It has 'Best Accuracy' at '+- 1% +2'. What does the +2 mean?
Also, does 'Best Accuracy' mean that it is likely that my meter is worse than 1%? If that's the case, why state a tolerance if your readings fall outside of the tolerance?
Also, the meter has different ranges labeled '200u, 2000u, 20m, 200m, 10' and the website says these refer to 200mA / 2000mA / 20mA / 200mA / 10A. I thought uA referred to microamps? Is there a mistake somewhere, or does u and m represent the same unit with amperage?
I'm trying to make an LM317T constant current circuit as a laser driver. I need around 300mA, and I want to make sure that when my meter measures this the true value is not too large for the diode. I could measure the resistance between the adjust pin and output pin, but the resistance is so low (~3ohms) that I don't think the meter would give an accurate reading.
Thanks
