Author Topic: reading eschematic  (Read 4116 times)
Offline dikkombeTopic starter
  • Country: ao
reading eschematic
« on: October 30, 2011, 09:02:14 pm »
hello my name is dikkombe and study electronics and have difficulty reading schemes diagrams
Every war ends where it began: peace.
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: reading eschematic
« Reply #1 on: October 30, 2011, 09:02:58 pm »
and what do you want us to do about it ?  ;)
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
« Reply #2 on: October 30, 2011, 09:31:20 pm »
Hi dikkombe and welcome to the forum! Could you post a picture of the schematic you're having trouble with and point out the parts that need explanation.
Offline Simon
  • Global Moderator
« Reply #3 on: October 30, 2011, 09:37:25 pm »
if it is a large schematic you need to firstly break a schematic into blocks, depending on how much you know about electronics you may or may not know of many basic blocks that are used that have a function in themselves and do something for the overall circuit, so effectively you break the schematic into a block diagram. Hopefully you then know what each block is doing so you can understand the circuit at a block level and component level as well as functional
Offline Chet T16
  • Country: ie
    • Retro-Renault
« Reply #4 on: October 30, 2011, 10:34:27 pm »
Related to this, on schematics i've seen some connections to ICs have a small circle on them.
From my experience with logic circuits i would say this inverts the signal but not sure what it means in a circuit scematic
Chet
Paid Electron Wrestler
Offline Simon
  • Global Moderator
« Reply #5 on: October 31, 2011, 06:43:55 am »
what sort of symbol does the IC have, if it is a bow with however many pins the IC has no idea if it is a functional symbol like a flip flop then yes it means active low ie there is an inverter on the input (I think)
Offline vtl
« Reply #6 on: October 31, 2011, 06:55:28 am »
Its called a bubble and it means its inverted, ie active low
http://en.wikipedia.org/wiki/Logic_gate#symbols
Offline Chet T16
  • Country: ie
    • Retro-Renault
« Reply #7 on: October 31, 2011, 07:30:55 am »
Right, so it only tells you how the circuit works.
Simple example:
 http://www.sparkfun.com/datasheets/DevTools/Arduino/FTDI%20Basic.pdf
Looking at that now it would make sense, the reset pin is active low and the led pins sink current.
Chet
