Author Topic: Reading "mains" frequency from 12v -120v inverter with Dso213.  (Read 925 times)
Offline ThatDaneTopic starter
I've got a Dso213 on the way and a new "pure sine" inverter. My old inverter has bitten the proverbial dust after 10 good years of service, it was "modified sine".  I'm curious to see if this new inverter is truly a smooth sine wave.
The pocket dso I ordered has 1x and 10x probes . so I understand that I'd be using the 10x probe if I just slam it into the plug. But I'm willing to use a xformer. I have a few laying around,  some 10:1 and a couple that im not sure of but can test. I understand how to properly wire up a plug, what is hot/neutral/ground  and how to hook that to the primary of the xformer.
What is the best method? I don't want to nuke the scope, electrocute myself etc... Being that the thing isn't actually "mains connected" but making mains for me in my truck , how should I ground what should I do?
Offline radiolistener
Re: Reading "mains" frequency from 12v -120v inverter with Dso213.
« Reply #1 on: May 17, 2019, 02:47:30 pm »
disconnect your inverter from mains and disconnect from ground. Then connect it to accumulator and measure output
Offline exe
  • self-educated hobbyist
« Reply #2 on: May 17, 2019, 05:19:39 pm »
OMG, this question really pops up every... week. Short answer: use isolation downconverting transformer and measure the secondary because it's the safest way, provided you don't mess up with wiring. Long answer -- search forum ;).
Offline Ian.M
« Reply #3 on: May 17, 2019, 06:59:26 pm »
This question doesn't pop up every week - probing an inverter output is *NOT* the same as probing your utility company mains supply.
Direct connection is inadvisable unless you have name brand appropriately rated probes for a number of less obvious reasons, many of which don't apply to probing a utility company  mains  supply.  e.g:
* With inverters its unwise to assume that the output has a near ground Neutral - its quite possible it has two anti-phase Line terminals , as driving them in a full bridge configuration halves the HT DC bus voltage required for a particular RMS AC voltage.  Therefore it would be extremely unwise to clip a scope probe ground to what you *THINK* is output neutral unless you have verified direct continuity to chassis, ground terminal or the negative side (0V) of the DC input.
* Scope probes need to be derated with frequency  e.g. a x10 probe that's rated for +/- 400V at DC, may only be good for 200V at 100KHz.   With a switching waveform, its the edge slew rate that's important, so even if the inverter only uses a 10KHz PWM, if they've skimped on output filtering. there could be significant energy in the edges at an order of magnitude higher frequency, so you could well be pushing the limits of what a generic x10 probe can safely handle.  I certainly wouldn't care to risk it with a no-name switchable x1/x10 probe.
OTOH a transformer will cause some waveform distortion.  However if you don't want to splash the cash for a Cat II or better rated differential probe you may not have any other good safe alternative.
