The PCB is the BMS( Battery Managment System). It monitors the charge,temperature ,voltage ,balancing and so on. Check the batteries individually .Many times its just one or 2 bad ones that trigger the BMS to stop charging the pack.But also some BMS need to be reset to function again and it may only be programed for a specific charge rate for the batteries installed.
