Hey Guys. I'm doing the ATX PSU mod. My query is as follows. The Power on pin, green wire pin 16 on ATX I think. That wire, it is shorted to ground to turn it on. Now, what I want to do is use a darlington driver IC(what I have) to sort the two pins when anouther 5V input power source switches on.
I'm confused as to what the Power on pin, green wire, actually is. As if it was a 5V pin, it would be short circuited when grounded I think. As the input to the darlington driver would have to have current limiting there would have to be a resistor in there somewhere.
