Author Topic: Recommendation for high wattage soldering gun  (Read 2009 times)
Offline j_omegaTopic starter
« on: November 12, 2018, 07:50:59 pm »
I have a Hakko-888 that I am very happy with but I need another high wattage iron for bigger jobs. I have seen a lot of references to Weller D550/D650 models but have also read poor things about their quality control. What are the recommendations for a 150-250W soldering gun?
Offline t1d
Re: Recommendation for high wattage soldering gun
« Reply #1 on: November 13, 2018, 01:52:19 am »
Do you really want a gun style, or would you prefer an iron style, with that much wattage?
I have had the same Weller gun, for at least 30 years, but, in that length of time, Weller may have started taking shortcuts, on quality... I just don't know.
If you really want a gun-style, I would say to stick with the brand names; the no-names guns are definitely junk. Also, see "Mr. Carlson's Lab," on YouTube, for an easy to make, DIY tip, that helps pass the high heat, quickly.
High wattage irons are available. I am pretty sure JBC has them, but that will be big money. Also, I think the newer technology T12 type irons get that high... Here is a hack...
https://www.hackster.io/sfrwmaker/soldering-iron-controller-for-hakko-t12-tips-on-arduino-f7a888
For me, the iron-style would be the more versatile, and, therefore, the better choice.
« Last Edit: November 13, 2018, 01:55:38 am by t1d »
Offline digsys
    • DIGSYS
« Reply #2 on: November 13, 2018, 02:21:47 am »
I've bought several of these years ago - https://www.jbctools.com/hde-heavy-duty-station-product-933-category-1-menu-1.html
With the huge range of tips, we were soldering component level to literally gutter size - heavy copper bus bars > 1KW+ transformers.
Damn good work-horses, very reliable, fast and accurate. You can either get one of the lower rated units and use the larger tips. I do it all the time,
when I'm too lazy to swap stations :-)
Offline cdev
« Reply #3 on: November 13, 2018, 02:21:59 am »
I bought a high wattage soldering gun from Harbor Freight here in the US for I think around $10.
It does the job and even came with a case.
(Yes its cumbersome but for the price I can overlook a lot)
Its a lot like an old Weller.
« Last Edit: November 15, 2018, 12:47:24 am by cdev »
« Reply #4 on: November 14, 2018, 10:55:24 pm »
Well, I got my Weller gun in the mail today and found that it is much to cumbersome for my application.
It's a bummer than the Hakko and JBC high-wattage irons are so expensive...
Offline t1d
« Reply #5 on: November 15, 2018, 12:18:15 am »
How do you feel, about building the T12 type? If this is the type of electronics you enjoy, maybe it would be worthwhile?
« Reply #6 on: November 19, 2018, 07:35:40 am »
I finally found a solution. I used the JBC DD-1 that I found in my lab at work. It is a 150W iron and soldered the joint very quickly.
Offline digsys
    • DIGSYS
« Reply #7 on: November 19, 2018, 09:59:09 am »
Great news. You will like the JBC. If you need much more "effective" power, get one of the bigger ass tips. The station will easily handle it.
