Author Topic: Recommended MOSFETs, JFETs  (Read 3237 times)
Offline qu1j0t3Topic starter
« on: December 26, 2018, 10:58:22 pm »
I am playing around with a voltage follower and current amplifier circuit, and I noticed that I have almost no P-ch FETs.
Furthermore, just about all the JFETs available on Digikey are "switching" type, but I am more interested in amplifier type (Mouser seems to have more).
Does anyone have recommended P-ch (or N-ch) part numbers of either MOSFET or JFET type for follower/amplifier applications? Low voltage/low current in my case. I'd like to have a few of both N and P in stock for experiments.
(This question almost belongs on the "from no parts to stockpile" thread, but posting as a topic for better visibility…)
TIA & compliments of the season
Offline Psi
Re: Recommended MOSFETs, JFETs
« Reply #1 on: December 26, 2018, 11:14:49 pm »
The following users thanked this post: qu1j0t3
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: December 27, 2018, 12:34:42 am »
JFETs aren't fundamentally different; they are selected based on testing.  When you buy a, say, PN4392, you're buying a part that was tested to a switching spec, so it has so-and-so pinchoff voltage, Rds(on) and leakage.
You can infer the small-signal parameters from Vpo and Rds(on), if a bit sloppily.
A 2N5486 may not even have an Rds(on) rating, though it's pretty obvious what that value is from the curves.  It will however carry the assurance of so-and-so transconductance, capacitance, Y parameters, whatever, that you need in the design of an RF amp/osc.
And some RF parts may carry a noise rating, but noise depends on frequency too; expect 1/f or popcorn noise at low frequencies (audio, LF).  Conversely, low noise (LF) parts may be noisy at HF, though they're sometimes too big (e.g., J105) to use at high frequencies anyway so that's okay.
There are very few JFETs that you actually need/want, and this is reflected in the ever-shrinking market.  They're great parts when you need them, it's just very rare that you do. :-\
Seven Transistor Labs, LLC
Offline oPossum
« Reply #3 on: December 27, 2018, 12:44:43 am »
If this is for audio / low frequency application, then...  http://www.linearsystems.com/product.html
« Reply #4 on: December 27, 2018, 12:50:04 am »
Yes, currently, but I'm also considering what to keep in stock for the future.
« Reply #5 on: December 27, 2018, 01:17:15 am »
JFETs aren't fundamentally different; they are selected based on testing. …
Thanks Tim. I'll also accept recommendations for suitable MOSFETs (P/N) for amplifier/follower, to keep in stock.
Offline T3sl4co1l
« Reply #6 on: December 27, 2018, 04:37:22 am »
Offline Zero999
  • 0999
« Reply #7 on: December 27, 2018, 09:12:22 am »
Yes discrete J-FETs are rarely used these days and the same goes for low power MOSFETs.
For a voltage follower, just use an op-amp. It can be a J-FET input op-amp, such as the TL072, if you want a high input impedance.
MOSFETs are normally used for switching large currents, either on or off, rather than in the linear region.
If you want 10 or so N and P channel J-FETs for experiments, just order whatever you can get in a through hole package of, from a widely known distributor: Digikey, Mouser, Farnell etc.
Online Kleinstein
« Reply #8 on: December 27, 2018, 09:29:56 am »
p-Channel JFETs are very rarely used. So here it's about looking what is available, if one really needs one.
n-Channel JFETs are still used sometimes, but not very often. THT parts are getting rare, but there are still eve new SMD parts.
So if it needs to be THT the choice is usually limited.
The variation in the parameters is quite large. So most circuits that use JFETs are not very picky about the exact type. It is mainly for high performance that the type of JFET matters. With JFETs in TO18  some, made for switching have the gate at the case. This can be a bit odd when used in an amplifier.
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #9 on: December 29, 2018, 02:22:00 am »
For grounded gate RF amps, gate at the grounded case is ideal. This reduces unwanted feedback capacitance.
