Author Topic: A question about oscillators  (Read 1454 times)
Offline Fantasma25
  • Country: mx
« on: March 23, 2014, 06:40:20 pm »
Hello. I'm trying to design an audio effects board using a DSP form Analog Devices (ADAU1701), but I'm not sure about the oscillator part. In the datasheet it says
but I'm not sure which one I should buy since I don't really know what they mean by "AT-Cut Parallel Resonator" (link to digikey http://www.digikey.com/product-search/en?x=0&y=0&lang=en&site=us&KeyWords=12.288) or if I should do something like this
This second schematic is for the FT2232 that is on the hercules launchpad. I showed it because the oscillator connection in its datasheet is very similar to the one in the datasheet of the ADAU1701. What should I do?
Thanks!
Offline Paul Price
Re: A question about oscillators
« Reply #1 on: March 25, 2014, 10:59:03 pm »
http://www.digikey.com/product-detail/en/ABM7-12.288MHZ-D2Y-T/535-9837-6-ND/2001708  spec sheet shows AT-Cut
Almost all commonly sold xtals for this freq. are AT-Cut, so almost anything you can buy will work fine, just use the recommended xtal circuit as shown in the AnDev spec sheet
« Last Edit: March 25, 2014, 11:46:13 pm by Paul Price »
Offline VK5RC
« Reply #2 on: March 26, 2014, 12:27:40 am »
The second circuit to me,   looks almost identical except the case of the crystal is grounded,  usually only needed in rf environments (or noisy &  fast digital)
