Author Topic: Reduce rumble vibration  (Read 2076 times)
Offline Erwin Ried
  • Country: no
« on: March 06, 2014, 07:17:58 am »
I have a little wireless keyboard that I use with a raspberry pi, the keyboard is nice but it has an annoying noisy vibration.
How to reduce that vibration? simple resistor should work?
My website: http://ried.cl
Offline valentinc
Re: Reduce rumble vibration
« Reply #1 on: March 06, 2014, 12:39:21 pm »
    What are you reffering to ? A mechanical vibration ? I don't understand... Please explain...
Valentin
Offline Erwin Ried
  • Country: no
« Reply #2 on: March 06, 2014, 04:38:57 pm »
Yes, sorry a tiny small motor with a weight, but it rumbles too strong
Offline valentinc
« Reply #3 on: March 06, 2014, 07:49:24 pm »
     The motor is inside the keyboard as feedback when you press a key ? Or commanded by the raspberry pi ?
     If the power consumption of the motor is not high (and I guess it shouldn't be if it's one like those used in mobile phone) a simple series resistor will work...
Valentin
Offline Erwin Ried
  • Country: no
« Reply #4 on: March 06, 2014, 08:10:28 pm »
Yeah it is a small mobile vibration motor. I will try with a resistor
Offline qno
« Reply #5 on: March 07, 2014, 11:23:01 am »
What type model maker is it.
I can imagine, to save batteries, there is an option to switch it off
Why spend money I don't have on things I don't need to impress people I don't like?
Offline XOIIO
« Reply #6 on: March 07, 2014, 12:17:40 pm »
You could just disconnect it if you don't want it on at all, or measure the current/voltage it uses with a multimeter and find the resistor you would need o reduce it by half.
Offline Erwin Ried
  • Country: no
« Reply #7 on: March 07, 2014, 11:04:19 pm »
http://www.amazon.com/LOFREE-2-4GHz-Wireless-Keyboard-Windows/dp/B00EOFFO26 this is the keyboard.
Almost all the reviews in different places tell about the annoying vibration. It is useful, but it is so strong! It was pretty easy to disassemble but there was an extra screw below the acrylic surface, so it is impossible to do without denting the plastic. I also broke the small smd switch used to switch mouse/keyboard, but I had a similar switch (a bit higher, but solved cutting part of the plastic button).
Tested some resistors and a 100 ohm one leaves the device with a smooth almost invisible rumble, perfect as tactic feedback.
« Last Edit: March 08, 2014, 10:43:07 am by Erwin Ried »
