Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Reduce rumble vibration
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Reduce rumble vibration (Read 2621 times)
Erwin Ried
Regular Contributor
Country:
on:
March 06, 2014, 07:17:58 am »
I have a little wireless keyboard that I use with a raspberry pi, the keyboard is nice but it has an annoying noisy vibration.
How to reduce that vibration? simple resistor should work?
Logged
My website:
http://ried.cl
valentinc
Regular Contributor
Country:
Re: Reduce rumble vibration
Reply #1 on:
March 06, 2014, 12:39:21 pm »
What are you reffering to ? A mechanical vibration ? I don't understand... Please explain...
Logged
Valentin
Erwin Ried
Regular Contributor
Country:
Reply #2 on:
March 06, 2014, 04:38:57 pm »
Yes, sorry a tiny small motor with a weight, but it rumbles too strong
Logged
My website:
http://ried.cl
valentinc
Regular Contributor
Country:
Reply #3 on:
March 06, 2014, 07:49:24 pm »
The motor is inside the keyboard as feedback when you press a key ? Or commanded by the raspberry pi ?
If the power consumption of the motor is not high (and I guess it shouldn't be if it's one like those used in mobile phone) a simple series resistor will work...
Logged
Valentin
Erwin Ried
Regular Contributor
Country:
Reply #4 on:
March 06, 2014, 08:10:28 pm »
Yeah it is a small mobile vibration motor. I will try with a resistor
Logged
My website:
http://ried.cl
qno
Frequent Contributor
Country:
Reply #5 on:
March 07, 2014, 11:23:01 am »
What type model maker is it.
I can imagine, to save batteries, there is an option to switch it off
Logged
Why spend money I don't have on things I don't need to impress people I don't like?
XOIIO
Super Contributor
Country:
Reply #6 on:
March 07, 2014, 12:17:40 pm »
You could just disconnect it if you don't want it on at all, or measure the current/voltage it uses with a multimeter and find the resistor you would need o reduce it by half.
Logged
https://www.youtube.com/user/JunctionRunner
Erwin Ried
Regular Contributor
Country:
Reply #7 on:
March 07, 2014, 11:04:19 pm »
http://www.amazon.com/LOFREE-2-4GHz-Wireless-Keyboard-Windows/dp/B00EOFFO26
this is the keyboard.
Almost all the reviews in different places tell about the annoying vibration. It is useful, but it is so strong! It was pretty easy to disassemble but there was an extra screw below the acrylic surface, so it is impossible to do without denting the plastic. I also broke the small smd switch used to switch mouse/keyboard, but I had a similar switch (a bit higher, but solved cutting part of the plastic button).
Tested some resistors and a 100 ohm one leaves the device with a smooth almost invisible rumble, perfect as tactic feedback.
Last Edit: March 08, 2014, 10:43:07 am by Erwin Ried
Logged
My website:
http://ried.cl
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
