Author Topic: Component identification help  (Read 871 times)
Offline danamaniacTopic starter
« on: May 06, 2024, 02:59:21 am »
Hello everyboy, need some help identifying these components, ive searched google etc with the markings, just need to be 100% sure on this.
Pretty sure the sot23 components are transistors, however there are 2 banks of them and they have different markings.
The component marked with JF is ?, the diode beside it what kind of diode?
The other two weird 5 pin components i have no idea. Please help. Thanks
Online Kim Christensen
Re: Component identification help
« Reply #1 on: May 06, 2024, 04:11:52 am »
Here are my guesses:
64s   BAT64-04 dual diode
A7   1N4007W
JF   Fuse? Does it say F9 on the silkscreen next to it?
H58   XC6220B08BMR-G ??? 0.85V voltage regulator IC maybe?
HM   can be many things. Not sure at all.
1HW   BC847
« Last Edit: May 06, 2024, 04:15:20 am by Kim Christensen »
« Reply #2 on: May 06, 2024, 10:48:19 am »
Thanks for that, i think you are mostly correct.
Not sure about the .85v voltage reg, see attached picture.
« Reply #3 on: May 06, 2024, 10:49:07 am »
Anyone know what the component marked HW is?
Offline gamalot
  • Correct my English
    • Youtube
« Reply #4 on: May 06, 2024, 11:28:24 am »
Offline gamalot
    • Youtube
« Reply #5 on: May 06, 2024, 11:43:41 am »
In my opinion it is a MC74HC1G04.
https://www.onsemi.com/pdf/datasheet/mc74hc1g04-d.pdf
« Reply #6 on: May 06, 2024, 04:52:40 pm »
Just need help with HM (IC15) please guys thanks so much for help so far.
« Reply #7 on: May 06, 2024, 05:40:00 pm »
If you look here, if that's a SOT-23-5 package, then it's probably this one:
R1112N411B   Ricoh Linear voltage regulator IC LDO, LN, 4.1V±2%, 150mA, +CE
But if it's a SOT-353-1 package, then maybe a 74HC1G125GW as suggested by gamalot...
« Last Edit: May 06, 2024, 05:45:14 pm by Kim Christensen »
« Reply #8 on: May 07, 2024, 11:25:03 am »
Hi lads, this will paint more of the bigger picture to help us identify the last  component. Shows the Pin config and devices its connected to. Cmon we can do this :)
« Reply #9 on: May 07, 2024, 11:34:39 am »
Youre correct its an sot-323-5, stil not sure which component though.
Offline gamalot
    • Youtube
« Reply #10 on: May 07, 2024, 12:08:59 pm »
Why it has to be SOT323-5? Why can't it be a SOT353-1?
Again, it's a 74HC1G125GW  |O |O |O
« Last Edit: May 07, 2024, 12:11:29 pm by gamalot »
« Reply #11 on: May 07, 2024, 03:41:01 pm »
Seems to fit the profile:
« Last Edit: May 07, 2024, 03:43:56 pm by Kim Christensen »
