Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Reflowing my first BGA: Tips needed
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Reflowing my first BGA: Tips needed (Read 566 times)
lawrence11
Frequent Contributor
Country:
on:
September 17, 2019, 03:02:35 pm »
So I have my controleo3 all ready, its been "learned" and received high grade, the profile program has been tested.
I am reflowing on 1 chip ATM due to them being the only leadfree BGA of the gang, a 216 bga .8mm with no balls in the middle.
Should I risk aligning manually? Or should I contatc somebody with an xray to help? Is manually best I can good enough?
Should I put some flux on the pcb copper pads of the bga?
This my flux
https://www.amazon.com/Solder-Welding-Electronic-Soldering-Lead-free/dp/B076M49M63/ref=sr_1_47?keywords=solder+flux&qid=1568731253&s=gateway&sr=8-47
Logged
mayor
Regular Contributor
Country:
Re: Reflowing my first BGA: Tips needed
Reply #1 on:
September 18, 2019, 08:41:49 am »
When I did my first (and only!) BGA replacement, I watched as many Louis Rossmann videos on the subject as I could. Check it out, you might pick up a tip or two.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
