Thank you for your reply,I want design one PMSM Motor driver. so the Motor datasheet info as follows:
Max Speed:2900RPM
Rated Power:307Watts
Continuous Torque:1.65N-m
Peak Torque:5.37N-m
Continuous Current:8.90amps
Peak Current:29.4amps
Torque Sensitivity0.191N-m/A
Back EMF Constant:11.6V/kRPM
Ambient Temp.:25.0deg. C
I am a novice and I am studying hard. The problem I have now is that I want to design a DCBus circuit. I have read many books and have mentioned in the application that it is necessary to design a filter capacitor. So I’m stuck here. I don’t know what capacitance to choose, because I want the PCB design to be small enough, so I can’t use too big a capacitor.
The bus voltage of the motor is 48V.
The extra information is that the MCU I use is the STM32F4 series combined with DRV8301, then combined with TPS54360B, and LM2940IMP-5.0/NOPB, and then combined with TPS73533DRVR. My intention is to drive the MOSFET through DRV8301 to control U\V\W. , And then TPS54360B reduces 48V to 24V, LM2940IMP reduces 24V to 5V, and TPS73533DRVR reduces 5V to 3.3V. This is what I probably want to do.
I see some design schematics, either directly use a 1000uF capacitor, or use 8 100uF parallel (similar to ODrive), I don't know why they chose this way, I believe their choice must have a reason. So I want to figure out what they are based on? I am stupid. The Internet is full of various materials. I am confused about what I learn. I hope that my friends on EEVBLOG can help me so that my learning path will not become so difficult.
The above information is some information that I can sort out at present. If any information is still lacking, I will try my best to add it. Thank you!
