One of the adjustable linear regulator IC's is your best bet IMO. 317,337 etc
Nearly all of their datasheets have a simple PSU circuit.
Easy to implement, reliable, inbuilt thermal and short circuit protection as well as fold-back current limiting.
Their main drawback is dissapation, but if you limit your design to say 15 V that will reduce it lots.
Spend good money on a Bournes 10 turn pot, you won't regret it.
Good output terminals also make a PSU a pleasure to use, see if you can find some with 4mm cross drilled holes as well as suitable for 4mm banana leads.
Speaker cabinet types usually are good grunty types.
As for forum searches use the Search button close to the Home button for all searches.
