If you want to focus on your projects rather than having the power supply be a project and/or cause you to question its condition or safety, you may want to consider getting a linear lab power supply. Even if you weren't a beginner, it's a good idea to have at least one supply that you can rely on. Then, you can use it to design your second power supply.
My first power supply was an HP 6200B. An oldie, but a goodie, and still running in my lab. There are plenty of other quality used gear to choose from without breaking the bank.
If you indicate your budget, what voltage and current requirements you have, and any other special features, if any, folks here can offer recommendations.
Note that linear power supplies generally have much less noise on their output than switching power supplies, but are not as power efficient. Unless you're going to be driving something at high power settings for extended periods of time, I wouldn't worry about efficiency and go with a linear supply.
