Author Topic: Relationship between flux density, MMF and core area  (Read 2498 times)
Offline ZeroResistanceTopic starter
« on: October 31, 2018, 08:47:55 am »
Lets say i have a core area cross section of 1cm^2
And MMF I give is 100AT and due to this MMF in the core area I get a magnetic flux to flow which inturn causes a flux density B in the core.
Now if I double the core area to 2cm^2, but would keep the MMF same that is 100AT, how much would the flux density B change to?
My original guess was the B will halve, but I guess increasing the core area also reduces the reluctance of the core so more flux would flow for the same MMF.
So I would like to know the relationship between these 3 quantities?
Offline spec
  • MALE
Re: Relationship between flux density, MMF and core area
« Reply #1 on: October 31, 2018, 05:57:02 pm »
+ ZeroResistance
Bit of a head scratcher, but I will have a go at answering your question :)
The reluctance (Rm) of an inductor is, l/µA
where:
l is the length of the magnetic circuit in the core
µ is the permeability of the core material
A is the cross section area of the core.
So, if you doubled the cross section area of the core, you would half the reluctance, as you say.
It you half the reluctance you double the flux which means that, as the core cross section area has also been doubled, the flux density in the core would be unchanged, as you thought.
There is a further consequence of doubling the core cross sectional area: the inductance would also double, which means that the reactance, XL, would double (XL= 2ϖfL), which means that if you were pushing an AC constant current through the inductor, the voltage across the inductor would also double.
One thing that often causes confusion with inductors is that reluctance resists the magnetic flux in the core, but reactance resists the flow of electrical current in the inductor's coil. The two parameters are not the same. In fact, far from it: if you half the reluctance you double the reactance.
« Last Edit: October 31, 2018, 06:48:36 pm by spec »
The following users thanked this post: ZeroResistance
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: October 31, 2018, 08:39:43 pm »
What mu and path length?
If everything stays the same, you're just stacking two cores, using the same magnetization for each.  Doesn't matter if they're stacked or alone, you're just asking if it's two together, so the total flux is double of course. :)
Seven Transistor Labs, LLC
Offline spec
  • MALE
« Reply #3 on: October 31, 2018, 09:37:55 pm »
Take a cold shower Tim- you will feel better :)
Offline T3sl4co1l
« Reply #4 on: October 31, 2018, 10:59:28 pm »
You covered it in much better detail so I don't have much to add... I just wanted to get my shoe in :-DD
Offline spec
  • MALE
« Reply #5 on: November 01, 2018, 02:50:47 am »
Nice of you to say so :)
It had been a long day for me!
« Reply #6 on: November 01, 2018, 03:04:41 pm »
this is an interesting insight!! Thanks for sharing! :-+
Also lets not forget that scaling a core up will also affect the average path length the magnetic flux has to travel and that would have an overall negative effect on the flux as area would have a positive effect.
but anyway probably I got the answer to my question that the flux would double with area and B might remain the same.
But then that would mean both the cores will satuate at similar MMF values even though one is double the area than the other.  :phew:
« Reply #7 on: November 01, 2018, 03:06:26 pm »
Flux would probably double but B would remain the same wouldn't it?
Having said that to have a high attraction force what is necessary
1. more B or
2 more flux
Offline T3sl4co1l
« Reply #8 on: November 01, 2018, 06:40:25 pm »
Flux I guess?
The Maxwell stress is \$\sigma = \frac{B^2}{2 \mu}\$, in units of pressure (or energy density -- same thing).  If you have an air gapped core with so-and-so B in it, and ~no field outside the core, then this is the force pulling the gap together.  Or if you have two magnets pole to pole, then this is the pressure pushing/pulling on them (minus the pressures at the opposite ends, mind: there is a net pressure when they are unbalanced, of course).
Flux goes as \$\Phi = B A_e\$, but force also goes as \$F = \sigma A_e\$, so we can also say \$F = A_e \frac{\Phi^2}{{A_e}^2 \mu}\$ and one Ae cancels so it goes as flux squared per area.
It's like asking, "which matters more, the voltage or the charge on a capacitor?"  They're both fundamental quantities to the element, and the question implies more about the ignorance* of the one asking it, than its [direct] answer reveals about the subject.  :)
(*Not stupidity. Ignorance is good, in that it's why we ask questions.  As opposed to "you can't fix stupid".)
Flux isn't usually too important, for mechanical purposes, because you can almost always wait a little longer.  A solenoid might take 500us to charge up, but 5ms or more to actually move.  If it's not moving fast enough, you can increase the voltage, or goose it with some pre-drive or PWM it for constant current drive (as done with stepper motors).
Or how relays are usually noticeably slower to turn off when shunted with a diode (e.g., 20 or 30ms, on a relay that's nominally rated for ~10ms opening time).  Easy enough solution there, use a zener instead of a diode to clamp the flyback.  Dumping the flux into a higher voltage equals less time. :)
Offline spec
  • MALE
« Reply #9 on: November 02, 2018, 05:51:05 am »
But then that would mean both the cores will saturate at similar MMF values even though one is double the area than the other.  :phew:
No probs :)
Increasing the core cross section can increase the path length, but not necessarily substantially, take the case of a toroid for example.
There are a few counter intuitive aspects to inductors (and transformers). Your point about the core saturation does seem strange.
Another insight is that if you have an inductor with a constant AC voltage across it and you double the core area, you double the inductance and therefore half the current. This halves the MMF. So you have double the core area and half the MMF which means that you have one quarter the flux density in the core. :phew:
« Last Edit: November 02, 2018, 05:53:29 am by spec »
