Author Topic: Help with relay support components  (Read 563 times)
Offline TWilson
« on: December 31, 2016, 11:50:09 am »
I am trying to build a relay circuit. It is DPDT.
One relay contact on NC is connected to a battery, through a NO momentary switch which goes through the relay coil. This is just for initial mains free triggering.
The second relay contact on NO is connected to mains which runs a switch mode power supply to power the relay and run a motor.
I have an issue where I don't know if I need a flyback diode as well as a short delay capacitor across the relay coil. The capacitor is there to keep the relay open just long enough to allow the switch mode power supply to energise and provide current to keep the relay open. A momentary NC switch between the power supply and the relay is used to disconnect the relay and shut down the circuit. The motor bleeds off any excess power remaining in the power supply otherwise the relay gets reactivated.
I have also had issues where the circuit seems to get stuck open despite all power to the relay coil being completely disconnected.
Relay is a 5v coil with mains rating (240V) on the switches at 250mA.
Power supply uses 240V 5mA.
There is a 1N4007 diode reversed across relay.
Capacitor is 470uF electrolytic diode.
« Last Edit: December 31, 2016, 11:51:48 am by TWilson »
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Help with relay support components
« Reply #1 on: December 31, 2016, 12:08:21 pm »
always use a diode unless it interferes with your circuit.
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear and Wurth Elektronik Books.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
The following users thanked this post: TWilson
Offline tpowell1830
« Reply #2 on: December 31, 2016, 03:24:45 pm »
You should include a schematic, even if you sketch on a napkin and take picture. Then the text will explain what you're after.
PEACE===>T
PEACE===>T
