Author Topic: Diode Question  (Read 3258 times)
Offline vismund624Topic starter
Diode Question
« on: December 04, 2014, 05:09:50 am »
Hello all,
I feel like I must be doing something wrong. I have a circuit I am using that has an input and an output, to prevent people from accidentally supplying voltage from the output I put a diode in line. When using a thru hole diode this worked fine, but I switched to a SMD package as I am moving forward and it is passing voltage in both directions.
I supply 14.4Vs as this is a typical real world value for my situation and I would like this diode to be able to handle loads of up to 3 amps (Which is a little bit of overkill.)
http://www.mouser.com/ProductDetail/Panasonic/DB2440400L/?qs=sGAEpiMZZMtoHjESLttvkgPMEZYQGTCW58p%2fpfvUTc4%3d
That is the diode I am using. Note I have only checked this by putting the power supply and checking voltage with a multimeter, I have not put a load on this yet as i didn't think it would make much of a difference.
I checked the board is not shorted out and the diode is in in the correct orientation, is this just the wrong type of diode for purpose?
Panavision New York
Electronics Service Technician.
Offline suicidaleggroll
Re: Diode Question
« Reply #1 on: December 04, 2014, 05:16:23 am »
A diode can certainly pass voltage in reverse, it just can't pass a significant amount of current.  The data sheet for your diode says that it can pass 50uA at 40v reverse voltage.  This is probably enough to drive a multimeter, which is how you're measuring it.  Whether or not it will cause a problem with your circuit depends on your circuit.
Offline c4757p
  • adieu
Re: Diode Question
« Reply #2 on: December 04, 2014, 05:16:31 am »
Diodes don't "block voltage", they present a high impedance in the reverse direction which makes it difficult for current to flow. It still can flow, just not well. Except - your voltmeter barely requires any current at all, so even the tiny trickle that can pass through the diode is enough to be measured.
Perhaps the through-hole diode had lower leakage. Some Schottky diodes are really leaky.
Try adding a small load (a 10k resistor or so) permanently to the output and see what that does.
Offline Falcon69
Re: Diode Question
« Reply #3 on: December 04, 2014, 07:11:55 am »
It sounds like what you are trying to do is prevent people from hooking up the supplies in reverse polarity.  You need a Reverse Polarity protection circuit, comprised of a P-Channel Mosfet, Diode, and a Resistor.
Check this video, It is a good source to start.
Offline Seekonk
Re: Diode Question
« Reply #4 on: December 04, 2014, 10:04:45 am »
There is always a chance you did something wrong....overheated the diode soldering or left a whisker shorting out the pads.  A simple resistance check is the first step.  Most meters will show the normal forward voltage of 550mv in ohms.
Re: Diode Question
« Reply #5 on: December 04, 2014, 01:45:27 pm »
Thanks everyone, this is what I was hoping. I will double check with a small load and if it works 50ua leakage is fine for me.
Thank you Falcon this is a great resource I will probably implement this on the input of my device but I am not protecting reverse polarity I am just trying to stop people from accidentally supplying voltage in 2 spots as one of my output's connectors is also commonly used as an input on other devices.
Panavision New York
