Author Topic: RCA jacks for panel mounting, ground connection  (Read 2728 times)
Offline robert555Topic starter
« on: April 04, 2014, 11:45:04 am »
Hello!
I bought a few rca jacks on ebay. And i don't know how to connect the ground to the contacts?
Offline David_AVD
Re: RCA jacks for panel mounting, ground connection
« Reply #1 on: April 04, 2014, 11:48:56 am »
Simply solder to one of the ground lugs?  Any reasonable iron should do that fine with the right technique.
« Reply #2 on: April 04, 2014, 12:08:35 pm »
Jo thought about it I too, but it feels a bit dodgy. But may well do so if there is any better way to solve it.
Offline Holograph
« Reply #3 on: April 04, 2014, 02:35:53 pm »
If you want to be sure you get an excellent connection, loop the wire around and solder it to both points (just make sure it won't touch the center lug). If you have a Dremel, you can make it even less likely to fail if you put little notches at the bottom of the ground lugs, and wrap the wire all the way around, in the notches, and then solder it. The notches aren't necessary, but they would help keep the ground wire from being pulled away from the jack. But there shouldn't be much pressure applied on that wire, really, anyway.
You could potentially also source or make a grounding ring with a solder lug that has a hole, if you really want. Again, I wouldn't say it's necessary. And it would add a little more resistance that way. I don't prefer grounding rings.
Overall, you need to be more careful when soldering this than if you had a grounding ring because there's a lot more metal in this and you'll need to be sure to get it hot enough.
« Last Edit: April 04, 2014, 02:40:34 pm by Holograph »
Online linux-works
    • netstuff
« Reply #4 on: April 04, 2014, 03:32:30 pm »
solder to one of the legs.  no big deal.  nothing wrong with that.  its not rf, its just audio.
but - be sure not to melt the insulation if you use too much heat for too long!
Offline G7PSK
  • It is hot until proved not.
« Reply #5 on: April 04, 2014, 05:30:13 pm »
Will a spade connector fit the lugs.
Offline Monkeh
« Reply #6 on: April 04, 2014, 05:32:59 pm »
.. fairly clearly, no.
