If you have one of those component testers you can get the pinout of any transistor, you just have to trust what it tells you. A multivibrator like this ought to be very forgiving, it will work with the cheapest crappiest Chinesium transistors you can find as long as they behave vaguely like a transistor.
Solid state is easy, at least low voltage stuff like this, it's a lot less exciting if you hook something up wrong.
