Author Topic: How do you run a IN-12B Nixie tube  (Read 3375 times)
Offline Tom10000Topic starter
« on: March 23, 2018, 12:47:48 am »
Hello,
I recently bought a Soviet IN-12B nixie tube and I am wondering how to run it
here is a picture:
Offline Canis Dirus Leidy
  • Country: ru
Re: How do you run a IN-12B Nixie tube
« Reply #1 on: March 23, 2018, 05:21:00 pm »
Do you read Russian?  ;D
OK, more seriously. IN-12B does not fundamentally differ from other Nixie tubes. Indicator's anode is connected to high voltage source through current-limiting resistor, cathodes are connected to decoder with high-voltage capable output (such as K155ID1 aka 74141) or transistor switches:
http://radiokot.ru/lab/controller/28/07.png
http://jacoburge.co.uk/nixie-clock/
P.S. Some numbers from IN-12 datasheet:
Anode voltage (DC): at least 200V, 250V recommended.
"Digit" cathodes working current (DC): 2.5-3.5 mA
"Comma" (digital dot) cathode working current (DC): 0.3-0.5mA
« Last Edit: March 23, 2018, 05:24:47 pm by Canis Dirus Leidy »
The following users thanked this post: Tom10000
Offline james_s
« Reply #2 on: March 25, 2018, 06:23:13 am »
It's pretty easy, you'll need a power supply delivering at least 170V or so, an anode resistor calculated (using Ohms law and the forward voltage of the tube subtracted from the supply voltage) to deliver around 2mA. For the decimal point you need an additional resistor on that cathode to reduce the current further if you use that element.
