Author Topic: Remote power outlet switch + normal wall switch  (Read 1899 times)
Offline Djsajmy
« on: January 10, 2014, 10:09:52 am »
Hi all!
Is there a way to use a remote power outlet switch with the remote and a physical wall switch ?
The remote has two buttons (ON and OFF). I would like to be able to control the remote switch with the remote and another physical switch on the wall.
Is this even possible ? And if HOW ?
Offline Rerouter
Re: Remote power outlet switch + normal wall switch
« Reply #1 on: January 10, 2014, 10:15:58 am »
The best way is 2 way switching with a local power indicator your on/off really becomes a toggle so unless the wall switch is off will read reversed, but its the second safest way
Offline GeoffS
« Reply #2 on: January 10, 2014, 10:20:13 am »
Do you mean wireless remote controlled  power switches? The ones  I have,  have a button on them so you can turn them on/off without the remote.
Offline Djsajmy
« Reply #3 on: January 10, 2014, 10:45:43 am »
Yes, similar but my are without the little switch on them! Would I be able to put a switch on like GeoffS image ?
