Temperature measurement using a PN junction is usually done using the delta Vbe method where the difference in voltage with two different currents which have a fixed ratio is measured. So what you want is a fixed change in voltage at the two currents. We do not know the ratio of currents or absolute values used but my guess is that a low valued resistor, about 60 ohms, will yield about a fixed room temperature result. Adjust the resistance value to get the temperature you want.
I came up with 60 ohms from:
60mV delta-Vbe / decade of current at room temperature.
Typically 1mA is used for the high current and a 10:1 ratio is used.
60mV / 1mA is 60 ohms; I ignored the actual ratio since you will need to adjust the value anyway.
