Cerebus' set of curves comparing the motor types is really good, but I'd finetune the captions a bit, because the post classifies motor types as motors only, ignoring how the motor is
driven, and silently
assuming a certain (classical) way to drive it. So let me add some more insight:
For a universal motor the torque versus speed curve looks like this:
For a universal motor (which is just another name for
series wound brushed DC motor),
driven off a constant-voltage source, like would be the case with simple old-school power tools, the torque versus speed curve looks like this:
The curve looks like this because the rotation generates back-EMF voltage linearly relative to the RPM. Current (~ torque) flowing in the motor is the (Vsupply - Vback_EMF) / Z_motor, where Z_motor is approximately a constant. Hence, more torque can be had when Vback_EMF is small, to the point to "maxing out" or saturating the motor iron, necessitating a compromised motor design underdelivering at higher RPM. Think about: what if we lowered Z_motor (particularly resistance to increase efficiency) and then adjusted Vsupply dynamically to have just the torque we want??
For an AC induction motor it looks like this:
driven off the constant-frequency grid (which is getting more and more obsolete every day, although will remain in use for those use cases where it is good enough like simple fan motors) it looks like this:
.png&f=1&nofb=1)
It looks like this because when the RPM is dropping, the slip frequency (difference between f_supply and f_rotation) goes outside the optimal range, efficiency drops, power factor drops, and less torque is generated. Think about: what would happen if we adjusted f_supply dynamically??
For an AC synchronous motor it looks like this:
For a certain type of AC synchronous motor
driven off the constant-frequency grid, I'm not actually sure how usual such curve is.
And finally,
For BLDC motor or Permanent Magnet Synchronous Machine it looks like this:
For a BLDC (aka trapezoidal PMAC), or PMSM aka PMAC aka sinusoidal PMAC motor, which are
almost the same thing (for basic analysis, the difference doesn't matter),
driven with an appropriate inverter drive aka VFD, because unlike the previous motor types, these types basically refuse to work at all unless driven with the proper controller, it looks like this:
Now comes the catch, and this is important: basically
all the motor types shown perform roughly to this curve set
when driven properly*! So actually the motor characteristics shown by Cerebus are characteristics not of the motors themselves, but of the combination of the motors, and how the power is supplied to said motor types. There always is the option to deliver the power to the motor the better way, for example buy a so-called VFD or Variable Frequency Drive, which is now a low-cost off-the-shelf item for an AC induction motor. If you do this, then the AC induction motor starts behaving according to the last graph.
*) not saying directly-connected-to-grid usage isn't proper if the designer knows the compromised result is
good enough for the job, or if the better way is not available, as was the case in the past
(the first part of the curve, where the torque line is flat is the normal operating zone for a BLDC motor)
Though, there is nothing
abnormal running them in field weakening, when more RPM is needed at the expense of torque. Depends on what is needed. Your comment has the right idea though because looking at that particular curve, the constant-power region occupies, what, 2/3 of the curve, where in reality, not many systems operate on the right-hand end of the curve.
The idea of having constant torque, or said even better:
whatever torque is asked for (below some maximum, obviously), is the key to understanding the idea of using proper motor drives. The advances in semiconductors and control electronics have made such motor drives more appealing during last three decades, making the curve sets as seen here (except the last one!) more and more obsolete as days go by.
And yes, I have designed and built such drives for many motor types: for "universal motors", brushed DC, steppers (which is actually a special case of a 2-phase reluctance motor), 3-phase induction, obviously BLDC, but also 1-phase induction (actually a special case of 2-phase induction). And when you drive them properly, they perform completely differently to how they are "supposed" to perform when driven "traditionally" i.e. suboptimally.
