Me either. I can put in bodge wires to traces and SMD pins with the kynar like this almost all the time. I bend form the middle section of exposed wire over the point of a micro chisel (other end of the stripper) to get it where it can be connected (to say line up over a short section of scraped trace) and it actually remains lined up when I solder, make joint, shear it off. To a PCB pin/pad, bend the end into an L or more acute bend to get it to touch where you want and not short. Pie's the limit when the wire stays placed and oriented how you want it to while soldering it.
Jumpers short as a even having just a few mm insulation, no problem. Just have to leave plenty of exposed wire on the first end, to slide the insulation bead down.
Takes just a tiny spell to figure out which end has to be soldered first to get it to go seamlessly. Rarely, rarely, ever have to cut the second end of the wire prior to soldering. I have a proper iron stand, so swapping between iron and stripping/cutting tool is very easy without looking.
The main reason to use enamel wire for PCB jumpers, in my book, would be if you ever need/like to completely hand wire high density SMD stuff. If they were to obtain the right tools and learn the simple techniques, I think most enamel wire folks would jump ship.
Most of the techs I have introduced and taught this method have been initially skeptical. Some are so smart or stubborn they immediately tell me why their way is better, and no, thank you. Every one that has actually tried it has been converted and thanked me, later, and their stripper/chisel is a cherished tool for PCB rework. If and when they have left the company, their stripper tool guaranteed goes with them.
