Author Topic: LC filter for noisy power: diode needed?  (Read 2630 times)
Offline PeteAUTopic starter
« on: April 11, 2016, 11:53:03 am »
I want to add a little LC filter to a noisy power supply (car!) and am wondering if I need a flyback diode?
Is D2 necessary or superfluous?
Offline uncle_bob
Re: LC filter for noisy power: diode needed?
« Reply #1 on: April 11, 2016, 12:17:32 pm »
Hi
Simply for noise, both diodes are technically "superfluous". They are there to take care of fairly normal spike events. I would include both of them, but a lot depends on exactly what the problem is. I also would put a fuse in front of the diodes that is rated at much less than the diode's current rating.
Bob
Offline danadak
« Reply #2 on: April 11, 2016, 12:18:12 pm »
Its dependent on load and value of L. Basically when you disconnect
an active load the catch diode will prevent high V transients. So for the
pennies a diode costs I would add it. Also consider a zener on output
to catch load disconnect transients.
Regards, Dana.
« Last Edit: April 11, 2016, 12:30:40 pm by danadak »
« Reply #3 on: April 11, 2016, 12:20:26 pm »
Yep, that's what I figured. But, should I put the diode in parallel with the inductor instead of going down to GND?
Offline uncle_bob
« Reply #4 on: April 11, 2016, 12:22:23 pm »
Hi
They are fine as shown.
Bob
