Author Topic: Removing PCB burn  (Read 24631 times)
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
Re: Removing PCB burn
« Reply #25 on: December 08, 2011, 10:13:02 am »
must be an inner track.
That is verry unlikely probably there is something dead after the jack
Oh, the joy of sending various electronics to silicon heaven
Offline stewmathTopic starter
« Reply #26 on: December 08, 2011, 10:33:53 am »
I soldered the new jack on anyway just to test to see what happened. Plugged it in and my laptop power adapter just shorts and turns itself off. I didnt mind trying this because my aparter has an auto turn off if theres a short or overload etc.
  • Country: hr
    • HackLordSniper
« Reply #27 on: December 08, 2011, 10:52:33 am »
Thats a great way to do more damage before you know where is the problem
« Reply #28 on: December 08, 2011, 11:02:00 am »
Would a broken component after the dc jack cause the dc jack to short though?
  • Country: hr
    • HackLordSniper
« Reply #29 on: December 08, 2011, 11:41:59 am »
It surely does
Offline Short Circuit
    • White Bream electronics R&D
« Reply #30 on: December 08, 2011, 11:44:32 am »
Yes, perhaps a fractured ceramic capacitor, or a broken TVS diode, or the fets from a synchronous DC/DC switcher.
Usually hard to find. Sometimes you can find the problem by applying a low-voltage high current and check where things get hot,
but that requires a reliable and rugged PSU, capable of delivering 10-20amps at <1V.
« Reply #31 on: December 08, 2011, 12:16:11 pm »
@Short Circuit
As you can imagine im still learning, i dont unfortunatly have a psu with those capabilities. Just a very good universal laptop adapter and a couple of decent multimeters.
  • Country: hr
    • HackLordSniper
« Reply #32 on: December 08, 2011, 01:59:34 pm »
I would not suggest to try that. The problem can be much deeper than at the jack.
Did you truy to remove all hardware from laptop (cd drive, memory...) and see what will happen?
« Reply #33 on: December 08, 2011, 02:04:27 pm »
@hacklord
the laptop wouldnt power up before, power jack used to smoke as soon as plugged in and then adapter blew up. Thats why im using the universal one with short and surge protection.
All hardware is removed because laptop is in pieces and the motherboard is on my worktop.
  • Country: hr
    • HackLordSniper
« Reply #34 on: December 08, 2011, 02:51:20 pm »
Then you have a problem in the motherboard. If you are lucky the problem will be close to the DC jack
« Reply #35 on: December 08, 2011, 03:52:51 pm »
hack, yeah hopefully its one of the components near the DC jack. I had to replace the DC jack because the old one was buggerd and all burnt around the pins.
Online Fraser
« Reply #36 on: December 08, 2011, 08:34:44 pm »
My thoughts for your consideration....
Power sockets on laptops are open to physical abuse and can break free of the motherboard. This is quite a common occurrence with heavy handed or careless users. It is worth carefully inspecting the area around the power socket as the sort of heating you describe is uncommon in good solder joints working at less than 60A ! I mention this because it would be a pity to fit the new socket before ensuring that all is well below it  ;)
Now onto your fault. You stated that the meter buzzed across all socket pads... useful but please be aware that an Ohms reading can offer more information than the <20 Ohms buzzer. A physical short circuit is not likely between power plane and 0V unless the unit has been messed with at some point. A shorted component across said power and 0V rail is far more likely as has already been stated.
In such a case I would normally break out my Polar Toneohm which is basically a smart milliohm meter that leads the user to the lowest impedance across the power rails and so to the shorted component. Unfortunately these are expensive and normal multimeter's will not do the same job. I have been thinking laterally for you in terms of basic physics.
1. You could buy some freezer spray from Maplin (~GBP5) and spray it on the area of interest, say 10cm x 10cm around the power socket. Let it frost over, then apply power to the board from the laptop PSU. The short should cause a heating effect in the area causing the problem and also possibly on the feed tracks to it. The frost should rapidly disappear at those points and may assist you with tracing the fault. The problem will be if the laptop power supply goes into foldback and current limits to a level too low to cause any heating effect. You could also try putting the PCB in the freezer overnight and seeing if a frost forms when removed...that's free  :)
2. Buy a cheap Infra Red thermometer. I found some on ebay for around GBP10. These are like tiny single element thermal 'imagers' in that they 'see' heat and so you could apply power to the PCB and use the IR thermometer to trace over the surface of the PCB looking for an area of increased heat dissipation. This would hopefully be the location of the short as the PSU overcurrent current foldback will likely prevent the motherboard powering up to any extent and so little, if any IC activity will be generating heat.
3. MK1 eyeball, bright light and a 5X or 10X loupe.... its free and can often spot areas of localised heating. With all the heat generated at the power socket I would expect some pcb lacquer discolouration at the location of the short. A time consuming search process but cheap !
I still recommend very careful examination of the area directly under the power socket. If there was a dry solder joint, it could have caused localised heating that in turn damaged the PCB and interlayer insulation...causing a short circuit at the power input point on the PCB.
Good luck.... it will be a challenge without the normal repair equipment for this type of fault.
« Last Edit: December 08, 2011, 10:07:44 pm by Aurora »
« Reply #37 on: December 08, 2011, 10:02:19 pm »
Aurora, cheers for the help mate. I will try the freezer spray idea. Also my multimeter has a built in thermometer so that could be useful.
I did inspect the area under the jack under a microscope and it looked fine, apart from the black surface burn which came off with pcb cleaner.
