Author Topic: Repair Horizon CT 7.1 Treadmill  (Read 1051 times)
Offline sairfan1Topic starter
« on: January 14, 2020, 08:41:35 pm »
Hi I have Horizon CT 7.1 Treadmill that was working good, but for some reason i stop using and it was stilling in my basement for about a year, after start using again, initially it worked good but soon it got problem while starting up.
Initially when i turn it on while displaying self test it beeps twice and self test display gets stuck (refer to images) after about 10/20 minutes it beeps again gets normal and i was able to use it. after keep using for about a month, it totally stopped working, now when i turn it on self display appears, beeps twice and then nothing happens.
I googled the issue, found one post describing exactly same but did not get the solution, i was looking for some help where to start, what could be the reason?
« Last Edit: January 14, 2020, 08:44:14 pm by sairfan1 »
Offline thm_w
  • Non-expert
Re: Repair Horizon CT 7.1 Treadmill
« Reply #1 on: January 21, 2020, 11:27:18 pm »
Open it, take photos of the control boards, look for any: burned components, damage, leaking caps, etc.
What is the power source for it, 120V in?
Some information here but may or may not be relevant http://productload.johnsonfit.com/inc/uploaded_media/ba2e870dabd6373a48f8e138dfc9c56f/service_guide/54c14b21a33d970fb0beb252b7d83034.pdf
