148.5V sounds absolutely fine, you wouldn't expect absolute precision. From your photo, the screen geometry looks fine too.
Regarding the flickering top line, I have no explanation other than maybe the picture height is set slightly low. This used to be easy to diagnose because on analogue TV broadcasts, you would see white teletext data bits flickering at the top, these would normally not be visible due to slight overscan.
