Author Topic: replace 3.58MHz with 3.579545MHz  (Read 4677 times)
Offline ifrenideTopic starter
  • Country: dz
« on: December 28, 2019, 04:57:22 pm »
Hello, can anybody tell me, if i can replace 3.58MHz with 3.579545mHz?
best regards
Offline jeroen79
Re: replace 3.58MHz with 3.579545MHz
« Reply #1 on: December 28, 2019, 05:01:36 pm »
It depends on what you want to do with it.
  • Country: dz
« Reply #2 on: December 28, 2019, 05:04:05 pm »
hi Jeroen,
I only have 3.579545Mhz crystal , I want to use it with Zilog microcontroller.
best regards
Offline mcovington
« Reply #3 on: December 28, 2019, 05:28:18 pm »
Yes.  The person who specified 3.58 probably meant 3.579545 in the first place.  That is a standard crystal for American color TVs (old style, NTSC).  It is commonly called a 3.58-MHz crystal but is actually 3.579545 plus or minus some tolerance.
The following users thanked this post: amyk
  • Country: dz
« Reply #4 on: December 29, 2019, 01:17:29 am »
thank you Mcovington,but I saw some pcbs with 3.58MHz ceramic resonator or passive crystal with exacetly 3.58MHz,and other pcbs with 3.579545MHz,without problem.So when we need exact value and when we can use close value?
Offline groinksan
« Reply #5 on: December 29, 2019, 01:51:39 am »
I would hit the datasheet for the Zilog microprocessor. It should tell you the clock rates accepted. Personally, I think the 3.579545 MHz should be just fine. If the chip is used just to execute code (6502 or Z80 for example,) or virtually any analog-based application, then the precise value won't matter. If it was running something like a timing device, or some other application that requires precision, then theoretically the value would make a difference, and you'd then need to modify other components to match the speed. The thing to take away from this is basically how that Zilog chip will function, and then go from there.
Offline schmitt trigger
  • Country: mx
« Reply #6 on: December 29, 2019, 02:04:36 am »
Are you absolutely certain it was a 3.580000 Mhz crystal and not a 3.579545 one? Many people were lazy and used 3.58 as shorthand.
As others have described, the 3.579545 was the NTSC chroma burst frequency, and millions and millions of those crystals were sold each year. It was by far the cheapest and most ubiquitous crystal, and many commercial products unrelated to NTSC video used it.
« Last Edit: December 29, 2019, 02:06:13 am by schmitt trigger »
Offline mcovington
« Reply #7 on: December 29, 2019, 04:29:53 am »
Perhaps more to the point, it is extremely unlikely that there will be any detectable difference in how a microcontroller works with one vs. the other.
Offline CatalinaWOW
« Reply #8 on: December 29, 2019, 04:46:02 am »
As said before this was a frequency used in US TV sets.  They were made to lowest possible cost, so I really doubt that all of those decimals really mean anything, particularly if you don't have the crystal mounted in the test manner, use the test circuit and have your room controlled to the test frequency.  It is the nominal frequency.
If you are making a countdown clock for next Christmas or retirement you might care about all of those decimal places, but in almost all applications it won't matter.
Offline mcovington
« Reply #9 on: December 29, 2019, 09:03:29 pm »
I am not even sure 3.58-MHz (exact, 3.5800000 MHz) crystals have ever been made.  3.579545-MHz crystals are extremely common and are commonly called 3.58-MHz.
I have even used them to substitute for 4-MHz crystals in microprocessor circuits.
Offline Brumby
« Reply #10 on: December 29, 2019, 09:45:29 pm »
This is what I would expect:
I mean, if those crystals are as common as mud and there aren't any other frequencies in that vicinity which you would come across very often (if at all), then there is going to be a shorthand version of how it gets referred to.  Think of it ... if you're in a group off electronics people familiar with this area and you started referring to this common-as-anything crystal to 6 decimal places, then you're going to waste a lot of time reciting them and all those around you are going to look at you funny.  They know what you mean - and 2 decimals is all that needs to be mentioned to make it clear.
A lot of the time, the precise frequency isn't all that important when driving microprocessors unless you have critical time-keeping requirements.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #11 on: December 30, 2019, 03:51:29 am »
Yeah, worst possible case, NMOS Z80, it won't know the difference.  IIRC, they start getting loopy above 5 or 6MHz and below 2 or 1MHz.  CMOS CPUs work down to DC.
Anything to do with precise timing or output signals, that's an exercise for the student.
Seven Transistor Labs, LLC
  • Country: mx
« Reply #12 on: December 30, 2019, 03:30:14 pm »
One of my favorite ICs back in the 80s, was a device from National Semi, which generated a 60 Hz signal from a 3.579545 Mhz crystal.
It was a NM-something, and very useful for a timing backup for clocks.
Offline mcovington
« Reply #13 on: December 30, 2019, 03:42:58 pm »
MM5369AA, I believe it was.  I used it in, among other things, a power supply for astronomical telescopes (with 60-Hz motors, accurate frequency needed) in the first edition of my book Astrophotography for the Amateur.  The chip is no longer available.  I did a PIC-based circuit later to replace it.
  • Country: mx
« Reply #14 on: December 30, 2019, 04:40:35 pm »
Exactly, that was the part number.
To obtain 60 Hz from an oddball frequency such as 3.579545 MHz, it alternated the frequency’s division ratio.
As such, the output wasn’t a 50% duty.
Sadly it is now obsolete, but can be emulated with any modern microcontroller.
Offline boffin
« Reply #15 on: December 30, 2019, 05:06:54 pm »
We used to use 8870 DTMF tone decoders which also used a colorburst crystal. Always thought it was odd.
Heck, even the original IBM PC ran at a multiple of Colorburst for it's systems clock.  The main crystal was 14.318 (4x colorburst - which was also fairly common) main crystal; which was divided by 4 for the video system (3.579...), and divided by 3 for the main clock @ 4.77MHz
Offline edavid
« Reply #16 on: December 30, 2019, 05:51:07 pm »
(About the MM5369)
No, it did not, it just divided by 59659.  You had to tweak the crystal load to get it closer to 60Hz.
Yes, that is correct.
It was an old PMOS part that wouldn't run at 5V, let alone 3.3V, so it wouldn't be very useful today.
« Last Edit: December 30, 2019, 05:54:16 pm by edavid »
Offline edavid
« Reply #17 on: December 30, 2019, 05:53:37 pm »
Here is a datasheet for a 3.580MHz crystal sold by Mouser:
https://www.mouser.com/datasheet/2/741/LFXTAL032257Bulk-997159.pdf
I have no idea why it exists.
Offline james_s
« Reply #18 on: December 30, 2019, 06:19:31 pm »
I've always called the colorburst crystals "3.58 MHz", it's pointless to use gratuitous precision when it's not necessary to do so.
Some applications did make use of this frequency to work with standard definition TV and monitors as displays. In many cases though it was simply the cheapest crystal available since they were made in vast quantities for the TV industry. If you needed something in that general range of frequency it made sense to select 3.58MHz because it was dirt cheap and readily available.
Offline nigelwright7557
    • Electronic controls
« Reply #19 on: December 30, 2019, 06:27:04 pm »
If its just a Z80 clock I cant see why any xtal around that speed wont do.
Unless the same xtal drives a UART or some other time critical device.
The following users thanked this post: mcovington
  • Country: mx
« Reply #20 on: December 30, 2019, 06:27:55 pm »
My favorite theory? Because of non-technical purchasing people and lazy engineers who did not accurately  specified it.
That is why our engineering director required that we should always call  it as a NTSC Chroma frequency crystal.
Offline mcovington
« Reply #21 on: December 31, 2019, 03:42:40 am »
I've never seen it referred to as "3.580" either, but that's simply 3.579545 rounded to 3 decimal places.
Offline amyk
« Reply #22 on: December 31, 2019, 05:57:28 am »
A lot of early microcomputers in the late 70s/80s used this as a timing reference, allowing direct connection to a colour TV.
Offline Zero999
  • 0999
« Reply #23 on: December 31, 2019, 08:49:49 am »
(About the MM5369)
You're right about the duty cycle, but according to the data sheet, it was CMOS, not PMOS. It will work at 5V, but not at 3.579545MHz, which requires a 10V supply.
http://pdf.datasheetcatalog.com/datasheet/nationalsemiconductor/DS010820.PDF
« Reply #24 on: December 31, 2019, 09:21:29 am »
Only reason those crystals are around is because they had 2 major uses, TV IF oscillators and filters since 1954, and then, because they were a cheap and available item, they were then used in DTMF tone generators, developed by 1960, as a low cost precision reference oscillator for tone generation. Thus they were both a very cheap, and very precise, quartz crystal oscillator, and thus were used in the first microprocessors as a clock generator, because they were cheap, worked well with a single transistor oscillator, could be divided down easily with a 7474 to give you a roughly 1MHz clock with 50% duty cycle, and ran the processor at a decent speed.
That the clock was so close to TV line rates also helped with video generation, but the leading contributor to use was that you could get them very cheaply, and they were widely available, unlike any other crystal, and were a no set up device unlike a LC oscillator or any other form of oscillator. you have the design, apply power and, within the limits of your test equipment, it would work, and you could test it just using a regular TV set.
