Author Topic: Use of audio frequency generator?  (Read 3756 times)
Offline vinloveTopic starter
« on: November 24, 2020, 02:19:24 pm »
Hi All
Just got this vintage audio frequency generator 10hz -200 kHz.
This is a massive and heavy instrument built like a tank.
But what are the some of the real practical uses of this set?
Thanks
Offline madires
  • A qualified hobbyist ;)
Re: Use of audio frequency generator?
« Reply #1 on: November 24, 2020, 02:36:20 pm »
Signal source for measurements and trouble shooting of audio circuits.
Offline hexreader
« Reply #2 on: November 24, 2020, 03:03:21 pm »
A signal generator is a really handy tool for testing out an oscilloscope.
An oscilloscope is a really handy tool for testing out a signal generator.
The following users thanked this post: rumreich
Offline cdev
« Reply #3 on: November 24, 2020, 03:28:58 pm »
A fun thing you can do with one, is get a very flat piece of metal and a speaker or even better, some other mechanical transducers, like piezo transducers, and reproduce the "cymatics" experiments, using some sand, salt or similar powders.
This is endlessly fascinating.
For example, this is the original set of experiments done by Dr. Hans Jenny. He published a book ages ago "Cymatics".
Search on that term to find a lot of stuff.
https://www.youtube.com/results?search_query=cymatics
Also try it with fluids and transducers.
It would be computationally quite expensive to simulate this!
« Last Edit: November 24, 2020, 03:41:10 pm by cdev »
Offline Vovk_Z
  • Country: ua
« Reply #4 on: November 24, 2020, 06:18:06 pm »
- If you don't have any generator then to have one is better than not to have. (Sorry that I am KO).
Offline themadhippy
« Reply #5 on: November 24, 2020, 06:26:42 pm »
keeping unruly yoofs at bay.
Offline Wallace Gasiewicz
« Reply #6 on: November 25, 2020, 01:37:51 pm »
Perhaps:
Use it to inject an audio portion of an RF signal in a RF generator. Through modulation port. Many RF signal generators do not have a modulation unit built in, but do have a BNC for injecting modulation. You then get an AM signal for testing receivers both AM and SSB. Some RF generators will also modulate to FM.
Use it to design switched mode power supply, these things frequently use 100 KHz frequencies.
Use it as a microphone input to test radio transmitters, more reliable than shouting into the mic.
Use it to test speakers and headphones, and the audio response of audio amplifiers.
Use it to drive the neighborhood dogs nuts with the correct dog whistle frequency.
Test your own hearing using different frequencies
See if you can shatter glass.
Maybe an ultrasonic cleaner? These things usually require a big signal however. And a transducer.
See if high frequencies in an office environment make people nuts.
Turn an arduino input on and off rapidly
With the correct phasing maybe learn to "cancel" certain frequencies.
Use it to check the performance of capacitors and inductors at KHz frequencies.
I am not advocating any harm to anyone, just pointing out some of the applications of an AF generator. Also some of my suggestions may not be entirely practical.
« Last Edit: November 25, 2020, 01:41:56 pm by Wallace Gasiewicz »
« Reply #7 on: November 25, 2020, 10:06:28 pm »
Sounds like great useful tool to have in any Electronics DIY shed.
Thank you all for your inputs and explanations.
Offline Doctorandus_P
« Reply #8 on: November 25, 2020, 10:16:36 pm »
I think you can use it to generate audio frequencies.
Offline wizard69
« Reply #9 on: November 26, 2020, 01:04:13 am »
You could also irritate the neighbors dog without the neighbor hearing!
Offline Renate
« Reply #10 on: November 26, 2020, 04:08:56 am »
The main use is to send 10 to 50 Hz into an audio amplifier to determine the resonant frequencies of a wooden structure.
You may find that a little power can really cause the walls and windows to shake.
Offline SilverSolder
« Reply #11 on: November 26, 2020, 04:41:37 pm »
Interesting, what do you use that measurement for?
Offline Renate
« Reply #12 on: November 27, 2020, 12:22:03 pm »
Nothing. Just using a couple of watts to be annoying.
« Reply #13 on: November 27, 2020, 04:00:26 pm »
I was thinking, you might be able to use this method to find rattles in a car etc.
Offline Renate
« Reply #14 on: November 27, 2020, 04:43:47 pm »
Well, if you could get the bass funneled into the tail pipe it could be useful.
Heat shields and such things are very frequency selective for a rattle.
« Reply #15 on: November 27, 2020, 07:45:12 pm »
Yep, and various plastic panels in the car can resonate (if you have a loud stereo!)
« Reply #16 on: November 28, 2020, 08:51:05 pm »
Does it also get used for repair / DIY restoration of vintage AM / SW radios?
« Reply #17 on: November 28, 2020, 09:28:27 pm »
It absolutely gets used in radio repair. I use it all the time.
You can insert a signal into the start of the audio chain to see if it works and you can use it with a RF frequency generator to make a modulated RF small signal to insert into the antenna. Some RF generators do not have an audio generator built in and have a BNC input for modulation. This can be AM or FM modulation.
The following users thanked this post: vinlove
« Reply #18 on: November 29, 2020, 03:09:25 pm »
Great stuff !!
I am glad that I have this audio signal generator :)
It is 20 Hz - 20 kHz.
It is a 1980s vintage gear, and built like a tank, heavy and large set.
I would like to see some videos that utilise audio signal and RF generators.
Offline Renate
« Reply #19 on: November 29, 2020, 04:30:13 pm »
I use my Analog Devices AD9850 DDS module with an ATMega32u4.
I can generate log or linear sweeps of audio (or even higher to 40 MHz).
There's a sync output so I can sync my scope to the sweep.
It's an easy way to sweep audio things for frequency response.
Offline SparkyFX
« Reply #20 on: November 29, 2020, 07:22:55 pm »
One of the many paths that lead to TEA...
Support your local planet.
Offline cdev
« Reply #21 on: December 07, 2020, 03:15:33 pm »
Perhaps:
Infrasound - sound right below the frequency threshold that we can hear, has some interesting effects.
A badly adjusted elevator right next to the office of the SF department of public health's environmental services department used to generate infrasound (was measured) and it constantly made people feel uneasy.
This effect is used in film soundtracks.
