I have a new lab power supply which has single turn 10K potentiometers on it. It is difficult to set precise values with these pots. I would like to replace some them (voltage) with 10 turn 10K pots. But...I noticed that the minimum resistance on these devices is 100 Ohm, not zero, like I measured on the single turn pots. I suspect that this will be a problem. Any thoughts out there?
-ert829
