Author Topic: Replacing a fixed and a adjustable regulator  (Read 940 times)
Offline gkmaiaTopic starter
  • Electronics Hobbyist
« on: January 06, 2019, 02:41:32 am »
I looking for some help replacing a couple regulators. IC 101 and 107 on the schematic attached.
First one is a s-81250hg and the closest I found was:
https://www.ablic.com/en/doc/datasheet/voltage_regulator/S812C_E.pdf
Second one is a TK11640. I am struggling with this one because it is not fixed. It goes in increments of 0.5 from 2v up to 5v.
S-81250HG is here: https://www.digchip.com/datasheets/parts/datasheet/432/S-81250HG-pdf.php
TK11640  is here: https://www.datasheetarchive.com/pdf/download.php?id=6b04dbd83b9c95ca8b5539f6738b79f62a036b&type=O&term=TK1164
Offline mvs
Re: Replacing a fixed and a adjustable regulator
« Reply #1 on: January 06, 2019, 07:31:10 pm »
They all are fixed. TK11640 is 4.0V, TK11630 (IC107) is 3.0V, S-81250HG (IC101) is 5.0V...
Offline Zero999
  • 0999
« Reply #2 on: January 06, 2019, 07:47:08 pm »
The TK11640 is fixed and is made to the required voltage by the manufacturer.
No doubt all of those regulators could be replaced with fixed/adjustable low dropout regulators with a suitable current rating.
« Reply #3 on: January 06, 2019, 09:01:04 pm »
Thanks guys, those are the ones I found that are the closest ones with matching pins.
Sorry for such basic question. I am a beginner and don't want to get it wrong.
3v - Tk11630
https://www.digikey.co.nz/short/p73f72
5v - s-81250hg
https://www.digikey.co.nz/product-detail/en/ablic-u-s-a-inc/S-812C50AY-B2-U/728-1066-ND/3609196
« Last Edit: January 06, 2019, 09:13:43 pm by gkmaia »
