I have the old Logitech G930 wireless headset, who's battery is poorly performing now after several years.
Replacement batteries are 3.7V Lithium-ion usually between 600-800mah. However I'd like to replace it somehow with an 18650 cell as they are cheaper and I have tons
Ignoring the mechanical challenges fitting it, how would that work with a 18650's voltage going as high as 4.2v and would it charge correctly?
Also the normal replacement battery has 3 wires, black, yellow, red. Not sure if the 3rd is for cell balancing or not, or a temp sensor.
How would I get around that, thanks!
EDIT: According to some YT channel, the correct replacement battery has an internal protection circuit, so that would have to be added
