Hey everyone. I have a small portable speaker (doss ego II) that I've had for a few years and I'm thinking of upgrading the battery on it to have more capacity and have it longer lasting. The battery that is in there now is a single 18650 2200 mAh (which measures at 1744 mAh). I'm wanting to replace it with two 20700 3000 mAh batteries in parallel. I wired it up and it is working and physicaly fits into the speaker which is awesome, but I haven't tried charging or discharging it yet. The 18650 cell I took out is a protected cell and the 20700 pack I put into it is using unprotected cells. Is this a problem for this application? As far as I know (which is very little admitadly) the speaker is going to be handling all the charging and discharging with a low batter indicator and the cell protection is essentially a safety to prevent the cell from excessive current draw/ short circuits, etc? I was also reading that a BMS is only really required when running cells in series and not parallel?
Thanks for any insight.
