You are totally fine with your 10 turn 2W pot, those tiny trim pots used on the original design are useable for up to a few mW, i would guess 250mW max.
The power will go in no way through the pot, they are only used with signal levels. So - keep it the way you do right now, there shouldn`t be any problem at all.
