I have, in my "bin" some h-bridge circuits that are left from a previous project. These are not single ics, but made up with mosfets, and used to drive a 12V brush dc motor.
Currently I have a project where I have to switch some leds on and off, meaning that when one is on the other is off and viceversa. These are either blue or white LEDs but the rest of the circuit is 3.3V logic (but I have a 12V power supply). In order to get rid of these extra parts put to use those already assembled h-bridges, I thought of the circuit in the schematic below, thinking that putting a resistor in series with both LEDs would "take" the most voltage drop, thus protecting the reverse biased led (there's always one when the bridge is active) from dying.
Is this a sensible idea? If not, is it at least an ok reasoning (albeit not best)? If not again, where am I wrong?
Thanks
