Author Topic: Resistance across a 1k resistor cube.  (Read 3740 times)
Offline hamster_nz
« on: April 22, 2018, 12:47:06 am »
While lazing around flicking through the latest Diyode Magazine, I came across this little puzzle.
What is the resistance across a cube of 1k resistors? (see image)
There is a few nice ways to solve it, when insight comes to you.
Offline IanB
Re: Resistance across a 1k resistor cube.
« Reply #1 on: April 22, 2018, 12:59:04 am »
I would say 833.3 Ω ?
Edit: I could even say 833⅓ Ω now that the forum has been upgraded  :)
« Last Edit: April 22, 2018, 01:50:59 am by IanB »
Offline AlfBaz
« Reply #2 on: April 22, 2018, 01:27:33 am »
Easy, 12 x 1k resistors multiplied the alfbaz 1k cube constant of 0.069444'  :-DD
Offline rs20
« Reply #3 on: April 22, 2018, 01:45:03 am »
833.33... is correct. hamster_nz, did you deliberately angle the cube in your picture to make one of the insights more obvious, or is that just a coincidence?  :D
Online Brumby
« Reply #4 on: April 22, 2018, 01:47:13 am »
So would I.
I wouldn't have said it was that obvious.  After all, you need some angle to show the cubic structure.  But now that you've said that, there might be a few more who catch on.
Offline JDubU
« Reply #5 on: April 22, 2018, 01:52:08 am »
LTspice agrees with 833.33... ohms (1 V voltage source has 1.2 mA current through it).
« Last Edit: April 22, 2018, 02:07:46 am by JDubU »
Offline IanB
« Reply #6 on: April 22, 2018, 01:57:23 am »
LTspice agrees with 833.33... ohms (1v voltage source has 1.2ma current through it).
It's good that LTspice works then. It would be awful if LTspice failed on such a simple circuit...  :D
(Since this is a lighthearted thread and I am a stickler for correctness, I should mention some typography rules for units of measure. There should be a space between the number and the unit of measure, and case is important. Which means: "A 1 V source has 1.2 mA of current through it.")
« Last Edit: April 22, 2018, 02:01:33 am by IanB »
Offline JDubU
« Reply #7 on: April 22, 2018, 02:08:37 am »
I stand corrected! :)
steverino
  • Guest
« Reply #8 on: April 22, 2018, 05:45:58 am »
I get 5/6 * R = 5/6 * 1000 =833.33...
There's also a general solution for 12 arbitrary resistances which works out to be something like
(r1 || r2 || r3) + (r4 || r5 || r6 || r7 || r8 || r9) + (r10 || r11 || r12)
but I don't feel like typing in the derivation.
« Last Edit: April 22, 2018, 06:03:09 am by steverino »
Offline rs20
« Reply #9 on: April 22, 2018, 06:57:20 am »
False. If you set all the resistors lying parallel to the x and y axes (arbitrary choice) to infinity ohms (open circuit), but leave the 4 resistors parallel to the z axis at 1 kiloohm, then:
- Your formula gives a result of 2.5 kiloohm,
- In reality, the such an arrangement breaks the circuit, so the correct solution is infinity ohms.
Therefore, your proposed formula is wrong.
Actually figuring out the correct answer for the general case is a much harder problem than the all-resistances-equal case (because all the resistances being equal is necessary to pull certain tricks); I haven't figured it out yet (not having really tried though.)
« Last Edit: April 22, 2018, 06:59:16 am by rs20 »
Offline Kirr
  • Country: jp
« Reply #10 on: April 22, 2018, 07:37:54 am »
For verifying solutions you can try my online solver: http://kirr.homeunix.org/electronics/resistor-network-solver/
It solves the network by eliminating nodes one by one using star-mesh transform, until only terminals are left. (See examples, which include resistor cube).
A similar quiz: Find resistance across a 4D cube, then also resistance across an edge (singel resistor) of a 4D cube.
Offline hamster_nz
« Reply #11 on: April 22, 2018, 07:47:56 am »
I'll have to sketch them out.
I would be interested in hearing who solved this by which means, from LTspice, to changing to an equivalent structure that is obvious to solve..
My first solution was to split all the resistors in half and bisect the design, half way between the test points. Analysis is then a piece of cake.
steverino
  • Guest
« Reply #12 on: April 22, 2018, 07:56:36 am »
The solution I gave assumes real values for the resistors - not open circuit.  Perhaps arbitrary was the wrong term.  Correct in this case, no?
Offline rs20
« Reply #13 on: April 22, 2018, 08:05:09 am »
So we have two facts:
-- Your formula works when all the resistances are completely equal
-- Your formula totally fails as some of the resistances approach infinity
And you're still confidently asserting that it's correct for all arbitrary combinations of finite resistances? That's very very bold! The parallel and series resistance formulae always give sane results even when faced with infinite resistances, and yet it very specially breaks down just for you? Hmm...
Anyway, your formula is still definitely wrong. You can take my previous argument, replace "infinity" by "one gigaohm", and the same  disagreement between common sense and your formula will result. Your formula allows the current to jump freely between the three nodes one step away from the + terminal, and the three nodes one step away from the - terminal. In a real cube, this isn't allowed. This is why your formula gives absurdly low values when very high value resistors are placed in such a way that they provide a unavoidable barrier to current in a real cube.
I've got Maple v11.0 to provide a solution (to the all-twelve-resistors-may-be-different-to-each-other case), and the resulting formula is literally 6 pages long. This doesn't prove much on its own, though (I might have made a mistake in the system of equations I provided, and it's also possible that this 6 page formula could be greatly simplified.)
« Last Edit: April 22, 2018, 08:14:21 am by rs20 »
Online Brumby
« Reply #14 on: April 22, 2018, 08:10:35 am »
Equipotential shorting method - valid because of symmetry.
Yellow lines are connecting equipotential points.  Because they are equipotential, joining them will not affect circuit operation.
Section A is 3 resistors in parallel = 333.3 Ω
Section B is 6 resistors in parallel = 166.7 Ω
Section C is 3 resistors in parallel = 333.3 Ω
A + B + C in series = 333.3 + 166.7 + 333.3
= 833.3 Ω
30 seconds of mental arithmetic (but I admit I wrote down the three intermediate values).
« Last Edit: April 22, 2018, 08:19:55 am by Brumby »
Offline IanB
« Reply #15 on: April 22, 2018, 08:17:46 am »
My solution arose from observing the symmetry of the system. If all resistors have the same value then all parallel interior nodes of the network have the same voltage, which means they can be treated as if they were connected, which allows the network to be viewed as groups of parallel resistors. Following this observation the overall resistance is (1/3 + 1/6 + 1/3) · 1000 = 833⅓
steverino
  • Guest
« Reply #16 on: April 22, 2018, 08:27:59 am »
Relax my friend.  I simply reduced parallel and series combinations.  If my solution is incorrect, that's ok and I'll double check it in the morning.  If it looks ok to me, I'll post a copy of my notes.  If I find an error, I'll post that also and some kind soul can point out the error.  Now, it's 1:27am and I'm relaxing enjoying a glass of brandy.  Cheers!
BTW, I just looked at Digikey, and I don't seem to be able to find any infinite resistors!  :-DD
« Last Edit: April 22, 2018, 08:33:34 am by steverino »
steverino
  • Guest
« Reply #17 on: April 22, 2018, 08:48:47 am »
quick request.  Can somebody please post the ltspice file for the cube (i know, i'm lazy).  I'll use it to check my work.  Thanks.
Offline rs20
« Reply #18 on: April 22, 2018, 09:11:37 am »
For those curious, I got Maple (a symbolic algebra solver thing) to solve the general case (resistors in the cube arrangement, but each resistor may have different, arbitrary values). I've attached a printout of the worksheet, but the TL;DR is:
The formula for the resistance is 3 pages long, and has this form (where capital letters are the various resistances, in an weird arrangement explained in the PDF):
total resistance = (A*U*G*F*C*V + K*B*A*E*C*F + ...) / (U*A*B*E*V + K*C*G*V*F + ...)
Which is at least dimensionally consistent!
In the case where four parallel resistors are equal (resistance = Rz) and the remaining 8 resistors are equal (resistance = Ry), then we find:
total resistance = (Ry^2 + 3 * Ry * Rz + Rz ^ 2) / (2 * Ry + 4 * Rz)
Notably, taking Ry or Rz to infinity brings the whole expression to infinity, as Ry and Rz both have higher powers in the numerator.
Finally, setting all the resistances to 1000 gives an answer of 833.33..., which is reassuring :)
Btw, hamster_nz, the above is not how I initially solved the simpler problem: I initially solved in exactly the way that Brumby described. Unfortunately, that method can't be applied in the case where the resistors have different values, as the underlying symmetry breaks down :(
I'd be fascinated to hear if anyone has a non-maching-requiring method of solving the arbitrary case; I'll be the first to admit that I have no idea how to do it by hand.
Offline RoGeorge
« Reply #19 on: April 22, 2018, 09:28:58 am »
OK, then, the cube was easy, try this one: What is the resistance between 2 nodes A and B, in an infinite 2 dimensional square grid of resistors, each resistor having the same value, R?  >:D
« Last Edit: April 22, 2018, 09:32:09 am by RoGeorge »
Offline JacquesBBB
« Reply #20 on: April 22, 2018, 10:28:03 am »
This is a great solution Ian and Brumby !
I  worked out nearly the same way, considering the symmetries of the system, and  thus three
different voltages,  V, V1, V2, 0 ,  with by symmetry also I/3 or I/6 current, and got  the solution,
but  although this was easy to solve, I  did not use your brilliant shortcut.
which is to say that all summit with same voltage can be considered as being connected, which
then simplifies the solution as one can use the already know rules.
This equipotential trick  is powerful !
« Last Edit: April 22, 2018, 10:31:30 am by JacquesBBB »
Offline Wimberleytech
« Reply #21 on: April 22, 2018, 01:22:38 pm »
Here it is.
« Reply #22 on: April 22, 2018, 01:26:31 pm »
This was my method to solve years ago...still works!
A couple of months ago I decided that I wanted to build one of these cubes as a piece of desk art.  I toyed with some 3D printer corner designs and such, ordered some 1/2 watt precision resistors...ADD as I am, the project is still incomplete along with the other hundred that are incomplete...lol...but I am always busy!!
Online Brumby
« Reply #23 on: April 22, 2018, 01:57:55 pm »
A lot of us know that song only too well.
« Reply #24 on: April 22, 2018, 03:41:42 pm »
How about this?
Using superpostion, go out to infinity and ground the last (LOL) nodes.
Then insert a current of 1 amp somewhere in the center of infinity (LOL²).
That current will split into fourths (1/4, 1/4, 1/4, 1/4).
Now remove that current source and connected a different current source of 1 amp LEAVING an adjacent node.
The current leaving will split into fourths.
Now, for a linear system, we can add these result yielding 1/2 amp flowing in the resistor between the adjacent points.
1/2 amp flowing through R gives V = R/2
That voltage (R/2) resulted from a 1 amp source, so the equivalent resistance is V/I = R/2/1 = R/2
Edit:
After pondering further, I do not have to ground the array at infinity...just insert the first test current and then the second.
« Last Edit: April 22, 2018, 04:06:23 pm by Wimberleytech »
Offline drussell
  • Hardcore Geek
« Reply #25 on: April 22, 2018, 04:44:16 pm »
A cube is bad enough, but how about this one from xkcd #730?  https://xkcd.com/730/  :)
steverino
  • Guest
« Reply #26 on: April 22, 2018, 07:39:17 pm »
Here's an attachment that shows my work (no cheating, class!).  Let's see if I can get it imbedded in this message...
(Didn't have time to check this beyond a casual look.  It's Sunday and I have a SWMBO...)
« Last Edit: April 22, 2018, 07:59:38 pm by steverino »
Offline JacquesBBB
« Reply #27 on: April 22, 2018, 08:02:00 pm »
This is my solution, which  I did  before seeing the other answers.
As you  will   see, it it  quite different from steverino, perhaps because I dont have an EE background, but it gets the job  done.
Be warned that is  a draft that I took back from the trash can. It was done quite casually and not organised to be shown.
But when I saw the various posts, and the previous one, I thought it would be interesting to show the various approaches.
« Last Edit: April 22, 2018, 08:06:42 pm by JacquesBBB »
Offline rs20
« Reply #28 on: April 22, 2018, 10:51:53 pm »
JacquesBBB, don't worry about Steverino's solution, he's trying to solve the much, much more difficult case where all the resistances are different (rather than all being equal to 1k)!
Steverino, the parallel resistance formula allows you take take a group of resistors which connects precisely the same two nodes, and replace them all with a single resistor (which connects the same two nodes as before.) For example, if we had rX going from node A to node B, and another resistor rY going from A to B as well, then we can delete those two resistors and replace it with a resistor of value (rX || rY) going between A to B.
The main problem with your solution is that you're applying this formula even though r6, r9 and r12 do not connect precisely the same two nodes. For example, r6 goes from B to A, but r9 goes from B to C. Unfortunately, you're simply not allowed to apply the parallel resistance formula in this case.
Now if (and only if) the resistances are all equal, and if you apply the reasoning showed by Brumby, then nodes A, C and b become connected (therefore they become the same node), and only then does the parallel resistance formula become applicable. But because we had to assume all the resistances are equal to pull this trick, you're not allowed to claim that your approach gives a valid formula when all the resistances are arbitrary/different. (And, as demonstrated in my earlier messages, your formula gives clearly wrong results in certain contrived arbitrary cases.)
steverino
  • Guest
« Reply #29 on: April 23, 2018, 01:38:45 am »
Ah, of course, I see it now.  Thanks.
Offline Kirr
  • Country: jp
« Reply #30 on: April 23, 2018, 04:40:20 am »
Yep, this always comes up (as well as infinite grid). Since there are no apparent symmetries, I guess the easiest calculation is via tedious elimination of nodes one after another - Automated here - tick "Explain each step" to see the steps in detail. (Feel free to try it manually before checking the answer). :)
I am curious about optimizing this calculation, because simple brute force process doesn't scale too well. Exploiting symmetries is one way. Another is noticing repetitions, and simplifying them before solving the entire structure (Example). Have to find time to do more experiments with this.
Offline The Electrician
« Reply #32 on: April 23, 2018, 10:45:26 am »
For extra credit, using these designators and values for the cube resistors, calculate the exact resistance between nodes A and G, showing the result as an improper fraction.  >:D
Offline Kirr
  • Country: jp
« Reply #33 on: April 23, 2018, 11:32:20 am »
When ready, click to verify your answer, or to give up :)
The following users thanked this post: rs20
Offline rs20
« Reply #34 on: April 23, 2018, 11:38:12 am »
I already provided the arbitrary resistance closed-form formula back in message #18. Subbing in the values you wrote, the answer is: 6195184/1328873 Ohms.
Offline rs20
« Reply #35 on: April 23, 2018, 11:46:21 am »
Very nice! If I understand correctly, your solver is public domain, but closed source, right? I'd be curious to try adapting it to give closed-form formulae (i.e., the calls you currently make to GMP, make them to a symbolic algebra library instead, using variables instead of fixed rational numbers.) Would be interesting to see if it landed on the same solution as Maple after expansion.
Offline gamalot
  • Correct my English
« Reply #36 on: April 23, 2018, 12:16:28 pm »
Online Zero999
  • 0999
« Reply #37 on: April 23, 2018, 01:02:19 pm »
I prefer to use superscript and subscript for fractions, because I find it easier to read. 8331/3Ω.
Offline Kirr
  • Country: jp
« Reply #38 on: April 23, 2018, 01:20:49 pm »
Also nice work on the formula!
Correct about public domain and closed source. I'll probably clean it up enough for opening some day. However I'm also curious about adding symbolic solution to the solver. My only worry is that it can quickly grow out of control and turn out enormous in the end. Would be interesting to see memory requirement and speed on larger networks. Perhaps we could collaborate on this.
I guess the final expanded formula is unique for each network, so should be identical (other than order of terms in each sum).
« Reply #39 on: April 23, 2018, 07:14:58 pm »
In reply #18 you seemed not absolutely certain that your formula was perfectly correct:
"total resistance = (A*U*G*F*C*V + K*B*A*E*C*F + ...) / (U*A*B*E*V + K*C*G*V*F + ...)
Which is at least dimensionally consistent!"
and:
"Finally, setting all the resistances to 1000 gives an answer of 833.33..., which is reassuring :)"
I thought I'd give you another dataset to test.  :)
« Reply #40 on: April 23, 2018, 07:22:20 pm »
A general solution to this sort of problem is provided by graph theory:
https://en.wikipedia.org/wiki/Resistance_distance
This provides a comprehensive and compact way to compute the resistance from every node to every other node:
rs20 and kirr got the correct result.
« Last Edit: April 23, 2018, 07:24:35 pm by The Electrician »
Offline rs20
« Reply #41 on: April 24, 2018, 04:32:47 am »
Why do you think I suddenly sounded so much more confident? In other words, thanks for the extra test  :)  :-+
Fascinating! Haven't had a chance to absorb this yet, but I'm a bit blown away that such a general solution can be expressed so compactly in with fairly standard-looking matrix operations.
You don't need the code to be 100% utterly perfectly formatted and coded before open sourcing it! I understand this is a common hesitation, I certainly share it. But anyway, I'm certainly keen to collaborate!
Indeed, I suspect you're right about this. But a non-expanded or multi-step calculation (in which there are "temporary variables" or "intermediate values") might give a more compact representation. I'm not sure if all this is any use for anything, but at the very least it could be interesting as a purely academic exercise.
Also, your tool can simply refuse to give closed-form solutions for sufficiently large networks :-)
Offline hamster_nz
« Reply #42 on: April 24, 2018, 05:14:34 am »
If you want a trip down "old school computer magazine lane" check out this 1986 Byte magazine section:
https://archive.org/stream/byte-magazine-1986-07/1986_07_BYTE_11-07_Engineers_Toolbox#page/n167/mode/2up
It walks you though why matrix operations can model this problem, and eventually builds up to modeling a 741 OpAmp on a Commodore 64 (giving results with 1% that of SPICE!)
It almost deserves a thread of it's own :D
The following users thanked this post: Wimberleytech
