Is there a generic name for the type of ammeter that has zero in the middle of the scale and swings left or right depending on the direction of current flow?
Typically these are used for showing whether a battery is being charged or discharged.
Alternatively is it ok to put two unidirectional current meters in series, one with reversed connections to show the reversed flow? Will alternately driving the meters backwards damage them?
