Author Topic: Resistor color code help...  (Read 2114 times)
Offline casp3rtech
« on: November 20, 2016, 11:37:18 pm »
I can't seem to find this thing no matter what.. Resistor fried on a TV power supply and I can't seem to make out the color code using the colors I see.. Maybe I am doing something wrong. From what I can see its red, black, gold, orange, black... All code generators are giving me an error and even if i do it manually, it makes no sense.
Offline Yansi
  • STM32, STM8, AVR, 8051
Re: Resistor color code help...
« Reply #1 on: November 20, 2016, 11:54:54 pm »
If the left most band is RED (really cannot tell for sure from a photo with incorrect white balance), then it is 0.2ohm resistor. Err.... was.
Offline Andy Watson
« Reply #2 on: November 21, 2016, 12:00:29 am »
I think the left band is brown. The gold band is a 0.1 multiplier, so it's a 1.0 ohm.
Offline Yansi
« Reply #3 on: November 21, 2016, 12:06:51 am »
Yeah youre right. My mistake.
Guess that was a current shunt from a switchmode power supply. If this one is fried, the mosfet and/or the controller IC might be as well.
Offline Brumby
« Reply #4 on: November 21, 2016, 12:19:05 am »
If you take the bit of gunk on the left end of the body as a reference, the white balance wasn't too far off.
Here's my effort at rebalancing...
Offline casp3rtech
« Reply #5 on: November 21, 2016, 12:20:47 am »
I have added two more while changing light settings on camera. This part is from a TV power supply that was damaged from power surge. So far I have found 3 bad capacitors, one fuse and this resistor. The power supply is massive and I can't find it anywhere! The model is BN44-00744A
Offline casp3rtech
« Reply #6 on: November 21, 2016, 12:27:20 am »
The bad components locations so far...
Offline Brumby
« Reply #7 on: November 21, 2016, 12:32:57 am »
For the lighting conditions - and my assumption that the gunk is white (or at least neutral) - your first photo was closest to correct white balance.
As such, I see the first band as brown.  The extra photos support this.
